electrical to mechanical speedometer conversion
Old Sep 2, 2018 | 09:10 AM
Co_94_PU's Avatar
Originally Posted by Duty-Bootie
Sorry to revive such an old thread.......
Need a little guidance please.....Bought a 96 4-Runner 4X4 Tranni for my 96 4x4 Tacoma. The speedometer pick up's are slightly different. The 4 Runner was electronic and my Taco, Cable.
If I put the Taco one in the 4 Runner and spin the output shaft it does not turn the cable as it does in the original Taco tranni.
On closer inspection the plastic gears are slightly different diameters and the worm gear that drives them inside the casing too is slightly different size.........The smaller gear is not touching the worm gear of course....
What is the best/easiest way to make my Taco cable drive work in the Runner Tranni. Thanks in advance.....
Read the whole thread. Determine what you have and what you need and source the right part...
As indicated above it could be as simple as unmounting the electrical portion from the mechanical section and attaching your cable.
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
altydog
Jul 28, 2015 10:20 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
wilbertd
Jul 6, 2015 07:39 AM
