electric locker swap
Old Oct 1, 2008 | 11:42 AM
trbizwiz's Avatar
Originally Posted by M threezy
I got this sucker on my rear end and runs well, but it's not sealed well. I think it leaks around the pumpkin. I could have sworn I put a ton of RTV on there.
Can I just clean up the edges and apply some more sealant around it? Reason being, the holes were not drilled perfectly straight and its a pain to remove.
TIA!
If the holes arent perfectly straight, you might have a little viberation and that is breaking your RVT seal causing the leak. I know this because I had an axel alignment issue when I bought mine, and by the time I got 2/3 the way home the viberation had completely shaken the pumpkin off the axel housing and lost all the studs. Obviously mine was worse than yours, but it did leak and it was because of the viberation.
Old Oct 1, 2008 | 07:47 PM
Matt16's Avatar
Or maybe you didn't scrape down the mating surfaces clean enough- that's pretty critical. I took steel wool to both sides until they were shiny, then applied brake cleaner to remove the oil.
Old Oct 1, 2008 | 08:16 PM
olharleyman's Avatar
You could just swap the entire axle but the width is different. yours is 58" and the Tacoma axle is 60.75". You can just replace the third though.
How's it measure up to a 2 gen 4runner? I was thinking that I could cheat and do the same thing
jerusry
Oct 19, 2015 05:28 PM
coryc85
Sep 9, 2015 06:24 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
AaronM
Jul 8, 2015 07:15 PM
