EGR temp sensor
Old Oct 31, 2011 | 05:54 AM
toyotaPmanager's Avatar
EGR temp sensor
I remember reading about being able to put a resistor in that will make the ecu think it is there but cant find the thread. Just need to know the resistor size that was being used. seems like i remember it was a 10k ohm. Someone that has done this please verify. I am not looking for reason to or not to do this just the resistor size...thanks KG
Old Oct 31, 2011 | 06:22 AM
MudHippy's Avatar
Yes, 10k ohm. I've heard many say that amount of resistance will eliminate getting code 71.
Old Oct 31, 2011 | 06:28 AM
Thanks for the quick reply. I have one just wanted to be sure and cant find that thread.
Old Oct 31, 2011 | 05:26 PM
zero503's Avatar
2nd on 10k ohms, but i dont know where the sensor is, i removed my egr a wile back with no problems or check engine but id like to slap that on anyways. Do you know where it is? Thanks.
Old Nov 1, 2011 | 02:47 AM
TNRabbit's Avatar
Yes, it's 10,000 ohm resistor. I've been using one for 2 years now with no check engine light. You can pick up a PACK of them at Radio Shack for about $2.
Old Nov 1, 2011 | 07:57 AM
It you have one it is threaded into the egr tube with a two wire connector.
Old Nov 1, 2011 | 07:59 AM
Thanks i have one....actually several but i was trying to be sure on which one. Thanks
Old Nov 2, 2011 | 04:00 PM
1994 V6's Avatar
Ok about this whole EGR thing. My truck has been having some idlin issues and to basically sum it all up, if i unplug the vaccum line running to the top of the EGR, my truck runs fine? would it be ok just to pop a 10 ohm resistor in he line and drive my truck?
Old Nov 5, 2011 | 08:36 AM
turkey's Avatar
1994 v6 did you ever figure out your prob? im havin simillar prob i have a miss and run lean and have code 71. i unplug mine and nothing changes. i cant figure it out.
also my valve does work ive tested it by sucking on the vac line.
Old Nov 5, 2011 | 08:43 AM
baddest94's Avatar
Ok i have my egr blocked off and the check engin light stays on would like to see some pics on how to do this with a simple write up with what to do. I would love to get the check engine light of it gets on my nerves LOL
Old Nov 5, 2011 | 09:03 AM
turkey's Avatar
why did you take your egr off? has it caused any ping?
Old Nov 5, 2011 | 09:15 AM
MudHippy's Avatar
It's not hardly worth a write-up or pics. But if you insist, here's the rundown:
1. Unplug the EGR gas temperature sensor, letting the pigtail hang free.
2. Place a 10k ohm resistor in the engine wiring harness connector end(to the ECM) between the two exposed terminals. Securing/sealing it in some fashion inside the connector, so it doesn't fall out or corrode(solder, tape, glue, RTV, etc.).
3. Run the engine and see if the CEL has gone out.
Here's all the pics you need:
http://personal.utulsa.edu/~nathan-b...43egrgaste.pdf
Old Nov 5, 2011 | 09:22 AM
baddest94's Avatar
I didnt take it off its blocked off. The top vac hose i put a small ball bearing in. After a put the cam in i could get it to idle nice but it would run correctly. With it blocked off it idles and runs perfect
Old Nov 5, 2011 | 09:32 AM
baddest94's Avatar
Thanks mudhippy the only reason i asked is cause i dont know squat about electrical wiring on car/trucks. So just unhook the plug and put the 10k resistor in making sure it don't come loose.
Old Nov 5, 2011 | 10:19 AM
turkey's Avatar
did it give you high egts from the higher combustion temps?
Old Nov 5, 2011 | 11:57 AM
baddest94's Avatar
I really don't know LOL my gf dad use to work for toyota and when i couldnt get it right he came and looked at it and thats what he did plus advanced the timing to 9 deg if im thinking correctly
Old May 29, 2023 | 08:20 PM
eldoradojim's Avatar
i looked up 10k ohm resistors but they are all different watts? some are 2 watts, some are 1/4 watt...which one do i need ? thanks for any info..
Colington
Aug 13, 2015 02:21 PM
rjtrials
Aug 6, 2015 07:25 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
bryan34w
Jul 6, 2015 05:53 PM
