EGR removal on 3.0
#41
I want my EGR gone but there are facts that hard to not take in effect the fact is "EGR is considered a `metered intake leak' and was developed to reduce the combustion temperatures to below 2,500 degrees" which effect could damage you engine.
#42
Eliminate Your Check engine light
If you get a 10 ohm resistor and stick it in the egr temp sensor plug it should eliminate the code. If it doesn't switch to a 5 ohm. THis should also keep the truck from going into any sort of loop.
#43
Crossover pipe
get rid of you're stock exhaust crossover (either headers, or have a custom exhaust made with a crossover that goes under the tranny.) and no more headgasket issues.
i deleted my EGR when i rebuilt my motor, and when i started it up, no warm idle..cold idle is just fine, but warm idle is a no go....could this be related to my 3vz having no EGR now?
Blamalam
Mar 12, 2022 07:34 AM
