EGR Question
Old Oct 9, 2007 | 08:11 AM
4Crawler's Avatar
Yes, that is all the sender does, tell the ECU that hot exhaust gas is flowing through the EGR when it is supposed to be open. I would check all the vacuum lines for the specified vacuum at the specified RPM per the steps in the FSM. On those later model trucks, the EGR is controlled by vacuum switching valves (VSVs) and you need to make sure those VSVs are actualy working (electrically) and that they are not clogged internally with soot.
Old Oct 27, 2008 | 05:05 AM
swolfe2's Avatar
according to http://www.ncttora.com/fsm/1993/engine/26diagnosi.pdf, the EGR is "*5: Codes 27 and 71 are used only for California specifications."
I live in Florida, so should I just clear it out and not worry about it? Maybe just hope that Al Gore doesn't find my 4Runner...
Old Oct 27, 2008 | 05:25 AM
Team420's Avatar
This could also be caused by a vacuum leak...could it not? Before u go replacing expensive sensors...make sure there is enough vacuum to actuate the egr valve.
Old Oct 27, 2008 | 05:44 AM
swolfe2's Avatar
is this from tracing the hose out of the egr, or just listening for a hiss?
Old Oct 27, 2008 | 06:59 AM
  #25
swolfe2's Avatar
so I found my problem. I went out in the parking lot, opened the hood, and found this.
Do I need to buy all new wiring, or is there a better way?
Old Oct 27, 2008 | 08:02 AM
  #26
swolfe2's Avatar
deleted
Old Oct 27, 2008 | 12:06 PM
  #27
swolfe2's Avatar
deleted
Old Oct 27, 2008 | 12:18 PM
  #28
bipolarandproud's Avatar
Yeah there is a way ... you can solder it .I did this the other day on my vsv plug .
tj884Rdlx
Aug 28, 2015 12:04 PM
e_richard
Jul 30, 2015 06:50 PM
montanatruck
Jul 25, 2015 03:45 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
