easy way to loosen crankshaft bolt?
Old Oct 3, 2010 | 12:54 PM
JJ'89's Avatar
Originally Posted by Teuf
Question? Why wouldn't fifth gear, E brake, and blocking all four wheels work with a cheater bar? I do understand that the bump start works.
Worked for me...limiting factor is probably clutch slipping?
Old Oct 3, 2010 | 02:16 PM
richf's Avatar
I used the starter method last week when I replace the timing chain, water and oil pump.
To tighten the bolt I got it as tight as I could by hand and put the truck in gear, pulled the e brake and tightened to spec.
Wouldn't the bolt get a little tighter over time cause it spins clockwise with the engine? Just a thought that popped into my head
Old Oct 3, 2010 | 02:32 PM
DROPT's Avatar
why cant a drop my pan without removing the xmember or jackin up the engine? 2wd btw. looks like i could just pull it off?
Old Oct 3, 2010 | 03:18 PM
xxxtreme22r's Avatar
your truck is a manual trans 2wd you should not have to remove the crossmember to drop the pan.
I did not have to remove the crossmember to drop my pan in my manual trans 4wd. However I did have to remove the mounting bolts for the front diff resting the cv's on the lower control arms and removed the steering stabilizer. Removing the diff completely and removing the crossmember, just makes it easier.
Old Oct 3, 2010 | 03:20 PM
  #25
raydouble's Avatar
The easy way?
The correct tool to hold the crankshaft or an impact.
Old Oct 3, 2010 | 05:03 PM
  #26
wbthornton88's Avatar
on the 3vze you can get like a 2 foot chain and bolt one end to the pulley in front of the crank shaft using the pulley bolt. Then rap the other end around the chassis double back and run a bolt and nut through the links to hold the chain to the chassis. Then break the crank pulley bolt.
Old Oct 4, 2010 | 09:34 AM
  #27
BajaRunner's Avatar
Originally Posted by DROPT
DUDES! IVE HAD THE BOLT OFF FOR AWHILE NOW!!! now im curious as to how im gonna get it torqued back on
I've never done it, but I've been planning on doing my timing chain here for a while so I've thought about it in my head.
But to me, putting it in a higher gear, like 5th would be harder to turn the crank than it would in 1st, no? Thats what you'd want...you want the crank to stay put while you torque the bolt. Put ebrake on, chock wheels, etc.
Take your torque wrench and find a steel bar to slide over it and hope you can get enough torque to turn it to ~180 ft-lbs.
Old Oct 4, 2010 | 12:28 PM
  #28
andykrow's Avatar
I think the clutching slipping is more the issue than anything else. I just put it in 5th and block the wheels. Put a three foot breaker bar on it and crank till the clutch can't grab it anymore. I'm sure this is completely the wrong way to do it and I'm not getting a torque reading but I've never had a problem. ...not that I'm telling anyone not to use a torque wrench... this is just what I do.
FYI torque on the 22re crankbolt is 116 ft/lbs... not crazy high like the 3.0
Old Oct 4, 2010 | 04:52 PM
  #29
raydouble's Avatar
Originally Posted by scope103
If you take that bolt out, you're going to want to put it back in someday. And the torque is 181ft-lbs for the 6cyl, slightly less for the 4cyl. How are you going to do that?
Actually Toyota upped it to like 217 ft/lbs on the 5VZ 98 and newer.....
Old Oct 4, 2010 | 07:12 PM
  #30
JJ'89's Avatar
Yeah, I just put it in 5th and set the parking brake and chocked the rear wheels on my 89 22re. Socket on a 24" flex handle loosening and tightening worked OK. I was thinking more like 120 lb.ft. on the install torque. Two foot lever to get 120 lbft works out to about a 60 lb pull. Wasn't a problem for me.
Maybe I'm just lucky, but it had never been disassembled before I did my timing chain at 150,000 miles...
Old Oct 4, 2010 | 08:31 PM
  #31
Smeddy2's Avatar
Yeah I put it in fifth and chalked the wheels too. Big ol pipe and had my friend stand on the brakes...came off nice and easy.
Old Oct 4, 2010 | 09:18 PM
  #32
Teuf's Avatar
My Mechanic said he used an air gun to get the pulley off to do my oil pump seal, a few years ago. This was pre YOTATECH days. If I had know then, I would have had him do a ready seal sleave or a slimmer oil seal.
Old Oct 5, 2010 | 07:17 AM
  #33
andykrow's Avatar
Does your seal leak? Those sleeves are easy to do - I got the one that comes in the fel-pro kit from advance auto parts and it works great.
Old Oct 5, 2010 | 07:41 AM
  #34
Teuf's Avatar
It still drips a bit, so I think the new seal put in just fit into same grooves/groove. What is the size for a 22re? how is it sized?
Old Oct 5, 2010 | 09:08 AM
  #35
andykrow's Avatar
Umm not sure about the size but the fel-pro one will work. I think you have to buy the timing cover gasket/seal kit "w/ sleeve 'n' seal". It'll have a new oil seal and the sleeve. (And other gaskets you don't need but it only costs like 14 bucks for the whole deal.) The sleeve is just really thin metal that you tap on, and it has a lip on it so it can't go too far. And it's still within the spec of the oem oil seal so you can keep the one you have.
The oil pump o-ring is another leak spot... It's pretty easy to crimp that o-ring a bit since it likes to move around while the oil pump is put on. That usually pukes out oil though if it's messed up, not just a slow leak.
nvdesertrunner
May 11, 2020 08:18 PM
upongame619
Aug 1, 2015 12:12 AM
pyramid
Jul 30, 2015 10:05 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
yourrealdad
Jul 21, 2015 11:13 AM
