Easiest Way to get Lim. Slip or Locker in my 2WD Auto?
Old Dec 18, 2008 | 12:24 PM
pmooney's Avatar
I'm not sure what route I need to go here: I have a 94 2wd that likes to spin one tire when going up boat ramps, sand, etc... It's a 22re, auto extra cab. Without going and buying a 4wd truck which I don't need, what's the best thing for me to do? Thanks for the help, It's such a good little truck and it does everything I need it too otherwise.
Old Dec 18, 2008 | 12:30 PM
space-junk's Avatar
id just look for a limited slip... you dont really need a locker if your just towing a boat...
Old Dec 18, 2008 | 12:47 PM
corax's Avatar
here's some good reading for you if you want to swap in a Supra LSD - I got my front LSD (4x4) for $30 from a "you pull it" type junkyard in about 1 hour from an '83 Celica Supra with the inline 6 cyl
http://www.4x4wire.com/forums/showfl...4&fpart=1&vc=1
the axle code on a 8" diff Supra will be Gxx5, on a 7.5" diff Celica Supra or early Supra the code will be Fxx3 (G=8" diff, F=7.5" diff the 3 or 5 indicate it is an LSD)
Old Dec 18, 2008 | 12:52 PM
Matt16's Avatar
How does that limited slip work up front, does it actually make a difference?
Old Dec 18, 2008 | 01:09 PM
corax's Avatar
It's better than an open diff, but it's benefit still goes away if I lift a tire off the ground (without some fancy footwork). I went with an LSD in the front when I was out in Cali because I knew I'd be moving back to PA and an LSD is supposedly much better in the snow (on road) than anything else (especially in the front) - the benefits in the snow have yet to be seen. Out in Cali it was fine in the desert and on dirt, no mud experience with it yet, either.
Old Dec 18, 2008 | 01:19 PM
swaycleveland's Avatar
i just did the supra lsd to my rear. i can tell the difference in the snow. the write up for mine is
http://www.gearinstalls.com/supralsd4.htm
i drive 80% street and the other is snow mud and whatever...
ill let you know how it works in the mud/whatever in a couple weeks when i hit the trails but im loving it so far plus for the money pleaseeeeeee
by the way CORAX
i have found applying the brake works real nice to lock mine up wheel in the air doesnt sem to effect mine as far as i can tell
Old Dec 18, 2008 | 02:42 PM
Jay351's Avatar
Try putting your e-brake on It will put more force on the rear drums then the foot brake. Should trick the LSD into sending power to the other wheel.
Old Dec 18, 2008 | 06:09 PM
corax's Avatar
definately let me know, there's a u-pull-it junkyard about an hour from me where I can pick up an LSD for <$50 . . . .
Old Dec 18, 2008 | 06:22 PM
abecedarian's Avatar
To help the OP out... (and me actually, cause I want one in my wife's 91 2wd)
...anyone want to explain how you can use a Supra LSD in a 2wd Toyota truck?
Old Dec 18, 2008 | 09:13 PM
space-junk's Avatar
corax, you can get LSD's for less than 50 bucks?? sign me up!!
Old Dec 19, 2008 | 04:26 AM
corax's Avatar
I thought I explained it
if the axle code in your truck says it has a 7.5" diff, you use a 7.5" LSD - if it says your truck has an 8" diff, you use an 8" LSD
Axle Code ID Article
all you have to do is swap out the differential itself (just the part that the ring gear bolts onto) and reuse the original ring gear -> The *official* 7.5" Supra LSD into a IFS diff thread
Old Dec 19, 2008 | 05:56 AM
CORAX.. dont bother waiting GO GET IT! if your doing it yourself i have somelinks for you about how to get more lock up out of it. if you have ZUK do it. he has the links already!
seriously GO GET IT we are talking about 50 bucks here and i can tell you its SOOOOO worth it!
Old Dec 19, 2008 | 06:27 AM
hross14's Avatar
Just saying--have a 4:10 True track setup by inchworm gear for sale--less than 5K on it.
Old Dec 19, 2008 | 07:14 AM
pmooney's Avatar
Thanks for the links, I looked at the code on the doorjamb and I have F302. This means I have a 3.73 ratio with a 7.5 rear end. I'll keep an eye out for the celica/supra diff.
Old Dec 19, 2008 | 11:47 AM
hross14's Avatar
Let me make this more clear--it is an 8" v-6 third member.
Old Dec 19, 2008 | 11:56 AM
corax's Avatar
Lurk around the classifieds at some of the Celica or Supra forums, I've heard of some people having luck there . . .
I like the link you posted and have actually already read everything on Zuk's site (good info there) - he was the one giving advice and instruction on the link I posted. I'll probably go with the rear LSD - just for the price, ease of install, and toyota reliability - I just need to wait for the weather to clear a bit for a u-pull-it junkyard run
Old Dec 19, 2008 | 02:00 PM
corax's Avatar
also just found out that if you can find a '90 Supra (JZA70 chassis), it has a Torsen LSD in it instead of a clutch pack machanical type - axle code G299
Jun 1, 2021 01:51 PM
Ironmike4x4
Feb 3, 2016 11:13 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
