early vs late idler arms?
Old Dec 26, 2008 | 01:03 PM
Matt16's Avatar
I know the later model idler arm (post '92) is a little beefier than the early ('86-'92). I am ordering a Downey Idler arm gusset and there is a different gusset for each idler arm.
Are there any features which easily distinguish between idler arms? I do not know the year that my junk-yard idler arm came off of.
Old Dec 26, 2008 | 02:37 PM
space-junk's Avatar
or, is it possible to upgrade a stock idler to the stronger style?
like me with my 90?
Old Dec 26, 2008 | 02:41 PM
Matt16's Avatar
I don't think the later idler arm is really much stronger, maybe something like 5% stronger, I don't know, whereas the brace/gusset is maybe 100% stronger.
Old Dec 27, 2008 | 12:21 PM
Jay351's Avatar
The diameter of the idler rod (haha...rod) is bigger then the 91 and prior units.
My downey idler arm brace was for a 1993 idler arm (I got the arm too) and it fit fine on my 91 arm..
Old Dec 27, 2008 | 12:57 PM
space-junk's Avatar
goot to know, thanks jay...
Old Dec 27, 2008 | 05:47 PM
Matt16's Avatar
There are two part number, on for each idler arm, which is confusing me.
Old Dec 27, 2008 | 08:42 PM
Jay351's Avatar
2wd and 4wd?
Old Dec 27, 2008 | 11:05 PM
Matt16's Avatar
Originally Posted by Jay351
2wd and 4wd?
No, don't think so, good guess though.
http://www.downeyoff-road.com/Suspen...s/1986-95.html
Steering idler arm gusset
Downey invented the Idler Arm Gusset; it is no more than another remedy for another problem. As we discover what can be bent or broken, we produce the bullet proofing. Most cases of bent idler arms are found on Toyota’s with 4 inch lift kits, but occasionally we find a bent Idler Arm on a Toyota less radically equipped, but more radically used off road. The idler Gusset is a simple bolt-on device, silver powder painted for lasting durability.
45486
86-92 4WD Gusset
$49.95
45493
93-95 4WD Gusset
$49.95
Old Dec 28, 2008 | 02:17 AM
Beaniam's Avatar
I would have sold you my later idler arm already with brass bushings, grease fitting and a downey brace on it since I'm sas'd now
ladybugRC
458
Aug 21, 2020 10:41 AM
Ditch Doc
Oct 27, 2015 03:20 PM
Gravel Maker
RuffStuff
Oct 4, 2015 10:26 AM
ktm192k
Oct 1, 2015 08:47 AM
