e-locker questions
Old Oct 27, 2010 | 10:00 PM
JonnyBoy's Avatar
Ok, just to clear some air, any v6 8" ring & pinion will work in the 8" E locker housing. I can't help you exactly on the wiring, I paid for a switch and harness, but there is a way to wire it in without relays. The kit I got just has wires to a toggle switch, although there's several connections on the back of the switch. You'd have to wire in the sensor that tells the motor when to stop so it doesn't continuously try to lock/unlock it. I believe the 4x4wire link has the particulars of making your own switch, if not there's info out there if you search google or something.
Old Oct 30, 2010 | 08:00 AM
Duffdog's Avatar
yes, you can totally use a momentary switch like you were thinking for the actuate/de-actuate motor. If it was me, I would use two relays and wire them "reversing polarity" to make the motor work.
heres how:
http://www.the12volt.com/doorlocks/page3.asp
Jun 1, 2021 01:51 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
AaronM
Jul 8, 2015 07:15 PM
