e-brake light getting annoying
Old Jun 11, 2010 | 09:11 PM
92 MurderedOut's Avatar
When I start up in the morning, take the e-brake off on my 87 truck and head on my way. But, the E-brake which is the pull type, keeps moving out apx. 2 cm just so the light pops back on, then I push it back into the dash and it goes off. This goes on wherever I go and I just want it to stay put haha. I searched and didnt find anything so please HELP!
Old Jun 11, 2010 | 09:20 PM
Jay351's Avatar
Go under the truck, look on the passenger side, near the t-case. You should see the union between the front e-brake cable and the rear.
tighten up the slack with the nut on the long threaded shaft.
Old Jun 11, 2010 | 09:23 PM
wyoming9's Avatar
Red face
Mine started doing that.
What happened was the front cable was starting to break and had started to fray and pushed the cable enough so the light would come on.
Something to look at maybe.
Old Jun 11, 2010 | 09:26 PM
85gijunk4x4's Avatar
unplug the e-brake light...lol jk but back in the day when my dad couldnt figure out why his check engine lights were on but his engines ran fine he would take the bulbs out...used to get him through inspection but not now with the obd doohickey things...
... i think there is a sleeve that goes over the e-brake handle shaft somewhere under the dash, just squeeze it with pliers a little bit, wont solve the real problem, but it will keep the handle from sliding out a bit
Old Jun 11, 2010 | 10:04 PM
hilandfrog's Avatar
Is there a repair for the ratcheting system...
It seems like as if ratchets out well it should "stick in" too??
Repo
Old Jun 12, 2010 | 05:53 AM
swampfox's Avatar
a quick fix is to wrap tape around the arm that pushes the switch in . like i said quick not correct.
Old Jun 12, 2010 | 05:59 AM
rattlewagon's Avatar
or put some black tape over the light. hah.
Old Jun 12, 2010 | 06:38 AM
se7enine's Avatar
I would do what Jay351 said, plus that brake assembly under the passenger gets really dirty and rusty. I would clean and lube it up. If it still does it after that tape a piece of LEGO on the brake stop.
Old Jun 12, 2010 | 07:54 AM
devldogs55's Avatar
Make sure you aren't low on brake fluid.
Old Jun 12, 2010 | 02:38 PM
The e brake is a mechanical brake system designed to work when the normal breaks fail or when the car is off. It is completely separate from the other breaks (other than using the rear drums) and does not require fluid.
Old Jun 12, 2010 | 02:46 PM
devldogs55's Avatar
RE.. I know that but when you're low on brake fluid your truck will let u know via the ebrake light. Worked for me. Though my light was on constantly and I couldn't turn it off even by pushing the button.
I topped off the master cyl and the light turned off immediately.
Old Jun 12, 2010 | 02:50 PM
He sad above that the lever keeps coming out and he has to push it back in to make the light go off. If the fluid was low, the light would not go off.
Old Jun 12, 2010 | 03:13 PM
devldogs55's Avatar
That's how mine started off till it got lower then it wouldnt turn off
Old Jun 12, 2010 | 07:21 PM
Jay351's Avatar
Yes it would. Low fluid will trigger the brake light to go off. To warn you to check the brakes.
like if htere is a charge problem, it throws a brake light and the charge light, tells you to stop and take a look haha
AkitaDog
Sep 1, 2015 08:05 AM
yipyip45
Aug 6, 2015 02:05 PM
priest16
15
Aug 6, 2015 07:43 AM
PopsDad1
Jul 30, 2015 02:21 PM
