dual cases question
Old Feb 24, 2009 | 06:53 PM
kinzer's Avatar
Originally Posted by Hayes
A triple shifter gives you all the control in the stock location...
please, do tell... i looked at the link but it doesnt explain much... do you have any pictures? im not sure how it would work, do shift rods go through each box or something??? you got me hooked and interested
Old Feb 24, 2009 | 07:55 PM
phildelfino's Avatar
Good links here, thanks. Nice work on the console Mt. Goat. Scotty's console is really nice.
Old Feb 24, 2009 | 08:13 PM
Hayes's Avatar
Merry Christmas
Old Feb 24, 2009 | 09:28 PM
kinzer's Avatar
thats awesome! your the man hayes! i want one
Old Feb 25, 2009 | 08:30 PM
  #25
kinzer's Avatar
so i think iv decided on what i want to go with so far:
front range off road T-case crosmember/skid plate combo ($299)
dr smash triple shifterer kit (~$400)
daves off road performance shift knobs X3 ($45)
and some other miscellaneous stuff
but theres one more question, i have a r150f tranny with a vf1a transfer, im told i have to have an adapter and a gear driven transfer behind the tranny and stock chain driven transfer, then the 10 degree adapter between the two transfer cases. is there any way i can use the same case i have now? or do i HAVE to add a gear driven one? id rather not have to use an adapter because it will put the shifter back further and i would then have to cut the floor and mod the center console defeating the purpose of the dr smash triple shifter...
Old Feb 25, 2009 | 08:35 PM
  #26
tc's Avatar
tc
In order to do dual cases behind a V6, you need an adapter to put a 4 cyl reduction box behind your V6 transmission, then another adapter to make the output of the reduction box like the output of the transmission so the second case can bolt to it.
For the second case, you can use either a gear drive case with an MC07 adapter or a chain drive case with the MC10-R10 adapter.
Old Feb 25, 2009 | 08:39 PM
  #27
kinzer's Avatar
ok i was worring i would have to do that... o well, not gonna stop me. so basically go grab a 4cyl case at spaldings ( i live like half hour away) and order the adapters, i need, do you know the depth of the first adapter?
thanks for the info
Old Feb 26, 2009 | 04:19 AM
  #28
mt_goat's Avatar
Interesting, just make sure you don't seal up the front (or rear for that matter) top plate with too much grease. That is the breather for the t-case and if one can't breathe it can push the gear oil out into the other case. When that happens you get one case running with too much oil and leaking out the top and the other case running with not enough oil.
Old Feb 26, 2009 | 09:47 AM
  #29
tc's Avatar
tc
Not sure how thick the first adapter is. I know the adapter, the crawlbox, and the second adapter add about 6.5".
the1998sr5
15
Jul 14, 2020 08:35 PM
yourrealdad
Jul 29, 2015 11:08 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
