Dream has came true.....
Old Oct 4, 2008 | 09:47 AM
sincal's Avatar
Ok long story short my motor in my 90 pickup (22re) has grown tired with its 297,000 miles. Today i found a 87 four runner engine (22re) that is brand new with only 3,000 miles on it, for $300. The only thing wrong with it is the previous owner had a shop install it into his rig and didnt tighten the head bolts down all the way and it leaked coolant out the side. (not into oil) due to they sued the company who installed it they are selling it for cheap. My question is would this work for my truck by just slapping it in?
Old Oct 4, 2008 | 10:02 AM
ontario4runner's Avatar
86 to 95 should be all the same so i am pretty sure it should be slap inable haha, i think everything was exactly the same.. i could be wrong though
that is one heck of a find thow
Old Oct 4, 2008 | 11:32 AM
scuba's Avatar
My old 86's engine is in my 91....Works perfect for me )
i love it actually
you should be good.
where is atwater btw ?
Old Oct 4, 2008 | 11:45 AM
sincal's Avatar
i love it actually
you should be good.
i atcually live in winton. behind atwater high.. the engine is coming from tracy
Old Oct 4, 2008 | 11:48 AM
scuba's Avatar
oh ok, just google map'ed it.
was gonna say if i was closer i could try and lend a hand.
But im in temecula.
Old Oct 4, 2008 | 11:52 AM
sincal's Avatar
yeah thats a tad far..lol but could use the hand..lol
Old Oct 4, 2008 | 12:51 PM
89silverpu's Avatar
It's illegal to swap in an older engine into a newer car due to smog emissions just so you know...that might cause some problems with registration if they know this....
Old Oct 4, 2008 | 12:54 PM
abecedarian's Avatar
that is true, unless the engine mechanical design wasn't changed between the years in question.
since a 22re is a 22re (well, all except the early ones), the long block assembly can be moved between years. The smog equipment itself cannot be brought forward from an older car to a newer car though.
*edit- this is California emissions. other states may vary
Old Oct 4, 2008 | 10:23 PM
sincal's Avatar
well i picked up the engine about two hours ago. All it needs is a head gasket due to i lifted the head to check pistons. Engine looks pristine. Its from a 88 runner i thought it was from a 87. It came out of a california truck so all smog equipment are same. I will use all my emissions stuff for this block but will get new water pump oil pump and timing cover as well as use my valve cover and oil pan. I am so happy its not even funny
Old Oct 4, 2008 | 10:38 PM
sincal's Avatar
by the way.. whats the least painful way to take my motor out and put this new motor in. IE.. mark cables take pictures, is there a write up. I have yet to pull a yota motor. Thanks for the help
Old Oct 5, 2008 | 12:28 AM
sincal's Avatar
nevermind i used the handy little search feature and think i got all i need to know.
cruisin69
Early Land Cruisers (Build-Up Section)
34
May 22, 2018 12:25 PM
viesail
Sep 21, 2015 06:00 AM
skoti89
Jul 6, 2015 07:45 PM
dodgeball03
Jul 17, 2004 03:09 AM
