Does anybody make 2nd gen 4runner leveling (1.5" lift) springs anymore?
Old Jan 26, 2011 | 10:25 AM
noble's Avatar
Unhappy Does anybody make 2nd gen 4runner leveling (1.5" lift) springs anymore?
Been searching and searching... A lot of people have liked the allpro 1.5" springs, I know downey used to make them (RIP) and eibach used to make some as well... But I can't find them anywhere anymore from either of the three... Has everyone stopped production of 1.5" lift (leveling) springs for the rear of a 2nd gen 4runner? I HATE the reverse rake... And really just excessive rake in general
And I feel like I deserve a pat on the back... I feel like I am currently one of the only 4runner newbs out there that has decided lockers and gears are a better investment than a lift... Although I am guilty as charged in getting 33x10.5 muds haha
Old Jan 26, 2011 | 02:42 PM
RobD's Avatar
Pick up a pair of Old Man Emu medium rate coils and a set of Nitrochargers and you won't be disappointed.
http://www.arbusa.com/uploads/PDF/ac...ota4Runner.pdf
Old Jan 26, 2011 | 04:53 PM
se7enine's Avatar
^ +1 on the Old Man Emu coils, had them on my 93 and it did the job fairly well
before OME coils
Picked up the rear nicely w/ no rake.
Old Feb 2, 2011 | 10:04 AM
noble's Avatar
thanks, will be picking up a set as soon as I sell a set of LC lift coils I've got... Sometimes I hate being a broke college student
Old Feb 14, 2011 | 09:52 PM
noble's Avatar
now... will I need a panhard drop bracket with the OME 900's? I wouldn't think so but just want to make sure before I throw them on with new OME shocks
Old Feb 15, 2011 | 04:49 AM
rattlewagon's Avatar
I think it would be a good idea
Old Feb 15, 2011 | 06:10 PM
se7enine's Avatar
It helps pull the drive shaft straight, if not it will be close to the gas tank and your rear wheel will stick out more on one side as well.
the drop bracket helps level the panhard real nice. I think I was off by 5/8" on one side.
Old Feb 15, 2011 | 06:33 PM
RobD's Avatar
I didn't, but then after that last post, I think I might take a look at how my rear suspension sits.
Old Feb 16, 2011 | 07:11 AM
Wrenchinjoe's Avatar
Just an FYI for the thread: I think the OME900 raises the back slightly over stock height such that folks either crank the torsion bars a bit or install ball joint spacers in front to truly level the truck.
If you are only looking to replace old tired springs without any lift over stock height, Moog makes a progressive rate replacement spring that addresses this issue. Search for Moog CC255, they cost $70-$80 from Amazon. I have read that they tighten up the ride very well and raise the back to original height, although after settling there may still be a slight rearward rake.
Sounds like the OME900 is a bomber product, but if you don't want to get into panhard drop brackets, torsion bar adjustments, or possibly longer shocks with a rear brake hose extension, then the Moog is a simple upgrade.
Old Feb 16, 2011 | 07:53 AM
Swim's Avatar
Correct, the OME900 will raise the rear about 2 inches. A panhard bracket is not required, but highly recommended.
Old Feb 16, 2011 | 06:24 PM
HighRunner's Avatar
NWOR still make springs for the 2nd Gen:
http://www.northwestoffroad.com/part...uspension.html
I have Downey HD's in mine, from back in the good ol' days when Downey still existed. The great thing about the NWOR kit is that like the Downey kit it also comes with the new extended brake line and brake valve proportioning bracket.
AustinTaco
Aug 22, 2022 10:45 AM
TNRunner88
Jul 1, 2015 08:00 PM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
