Do I have my crankshaft pulley on right?
This is my 1st time tearing into a diffrent engine other then 22R, hell its the 1st vehicle I've owned with more then 4 cylinders.
I want to make sure I get everything back together right, I never took off the lower timing gear, just the Harmonic Balancer pulley so I could get the belt off. But my belt is fine so I just put it back. But by checking here is it all mounted up right?
Thank you!
Thank you!
LOL Do I have to? I had to borrow a torque wrench that goes up to 180ft-lbs this morning to torque it down, and I already returned it.
If its consolation (spl) I could push my HB pulley pretty much that far in by hand, then just torqued the bolt on. I think its ok, I've double checked everything before I put it on. Just a little paranoid about that one thread.
charlie_fong
Sep 27, 2015 10:06 PM
