Difficult CV removal and front diff swap, 92 4Runner.
Old May 11, 2012 | 07:37 AM
meisentones's Avatar
As long as the old C-clip still has spring (i.e. is tight on the spline) then you can re-use. And yes, just hammer it back into the diff. It will "pop" in. Good Luck...sounds like you are getting there.
Don't forget the liquid gasket!
Old May 11, 2012 | 11:10 AM
Red Wagon's Avatar
I sheared off two bolts on my sway bar so I've now done the front sway bar removal mod. That's the second deletion mod I've done by accident. Ordering a rear non abs diff was the first.
I have the cv out now and have discovered my spare has a disk that sticks out where the one I pulled out is flush..... I hope the passenger side cv in the first Gen parts truck is the same.
Old May 11, 2012 | 01:47 PM
jslone's Avatar
Originally Posted by BMcEL
I just remove the four bolts on the lower ball joint, swing the knuckle out, and leave the CV studs in place.
That's how I did it and no problem with alignment.
Old May 12, 2012 | 11:10 AM
DixieThunder's Avatar
Sorry the head about your sway bar bolts but to answer you're question, no I through it back up right when I finished. Been thinking about taking it off for fun though. Maybe I'll do it whenever I actually get a day off of work.....
Old May 14, 2012 | 11:00 AM
  #25
Red Wagon's Avatar
I fly back to site Wednesday so looks like I'll have to put this down for a couple weeks.
Hopefully my panhard drop bracket will be in by the time I get home along with my rear sway bar disconnects.
Vargntucson
Jul 4, 2015 12:15 PM
Valvoman
Jun 28, 2015 02:45 PM
TheManOutside
Jun 18, 2015 03:32 PM
