Did a tune up, now I have a miss
Old Feb 10, 2008 | 08:25 PM
ovrebo1's Avatar
I bought my truck with 130K last week. This weekend I put a timing set, cap, rotor, plugs and wires. I also adjusted the valves just a tiny turn past spec. When I took the plugs out they were at a worn out .056 gap. I gaped the new plugs at .034, but it seems the next time I started the truck right after I did the plugs, which was the last thing I did, the truck has a slight miss at idle. Fine power through out, but just that slight occasional miss at idle. PLEASE HELP!!
Old Feb 10, 2008 | 08:50 PM
CJM's Avatar
CJM
Your sure its a miss and not an exhaust leak? Put the vehicle underload in par and see if it still makes it, then drive a bit and check. Look for exhaust leaks too..
I would duble check you have the correct firing order and installed everything properly as well.
Old Feb 10, 2008 | 08:57 PM
toytech76's Avatar
What specs did you adj your valves at? What kind of plugs did you get?
Old Feb 10, 2008 | 09:21 PM
ovrebo1's Avatar
never mind. I didnt seat a plug all the way. Lucky I was able to seat it. hope I dont have to heli coil a cylinder next time
Old Feb 11, 2008 | 04:49 AM
toytech76's Avatar
moparbay
Mar 10, 2023 03:50 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
Boomer8404
Sep 10, 2015 09:01 AM
larrys93pickup
Sep 6, 2015 06:37 AM
