default tire size?
default tire size?
What's the default/standard tire sizes for the 89 toyota pickup?
Also, with a 3" lift, what other tire sizes are able to fit?
I took a look at the truck looking for any sign of tire sized (on my sidekick, it had a sticker on the door well.) I couldn't find any sign, and the tires themselves are faded and worn away so I can't even make out their sizes.
Your truck rolled out of the factory on 225/75r15s, which are 28" tall. 31x10.5r15 is pretty popular size, and you can get away without re-gearing if acceleration isn't that important to you (with my heavy 4runner, stock 4.10 gearing didn't work for me).
You can fit a 33x10.5r15 easily, possibly even a 33x12.5r15. With those tires, you'll need to re-gear. A sensible gear ratio would be 4.88 with a 5spd, and 5.29 on an auto truck.
I found the factory sticker with the truck's tire info.
31x10.5x15 is the most common, and cheapest of the "bigger tire" sizes.
Great thing about the 31" tire is that a LOT of vehicle run them, so if you ever get stranded with a flat, just about any toyota would be able to help you.
Your current gear ratio will be fine for 31" tires. If you plan on driving it on the highway (assumably you do) you will need to regear if you plan on going any higher. For me, my trail rig doesn't see any road time, so I stuck with the stock 4.10 gearing, and let my dual cases do the work. They turn 33's just fine.
Having had both 4.10s and 4.56s with 31s, I'd say the $300 spend buying 4.56 diffs (no one buys 4.10s for much at all), was money well spent (even though I'm a broke university student). Keep in mind my truck is about 500lbs more than yours, but I found 4.10s really frustrating as I live in a hilly area.
djpg2000
Nov 11, 2020 04:56 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
