deep water VIDEO!!
Old Oct 19, 2009 | 09:57 PM
camo31_10.50's Avatar
hahaha..one of my buddies was playin around in the water in his 4wd tractor..(a BIG john deere..cant remember the model..had dual tires in the rear and the front tires were the same height as the back ones) out in some fields of his...forgetting where the pond was...and accidentally fell down into the pond..didnt hurt a thing though..came up to the cab on the tractor but he just kept goin and pulled on out..hahaha wish i woulda had a camcorder back then
Old Oct 20, 2009 | 04:45 AM
yotalaz's Avatar
well i felt my clutch slipping and a burning rubber smell so i backed out let it sit then it went away. but i was in 4wd high there, you could feel the strong suction on the car! i was like damn im stuck then i thought wait 4wd low! thats when you see me fiddling with the shifter then he shut the video off. 4wd low is awsome but i soon realized how unuseful 4wd high with out gearing down is. its way to tall for any good offroading. on the street im still in first when most cars are shifting into 3rd then i go into second gear.
Old Oct 20, 2009 | 09:11 AM
fireman1559's Avatar
here in alabama the red clay would suck that thing to the ground and gum up all your tires and youd be for the better part F*&$ed bad been there and got pulled out not fun but looks like alot of fun thou
Old Oct 20, 2009 | 09:35 AM
chrishf12's Avatar
NICE I havent gotten quite that brave yet! I dont wanna mess anything up and then have to fix it.
x2 on the red clay we have the same thing here in NC.
yotalaz just wondering what kind of exhaust you have on your 4runner it has a good tone to it in the video and isnt too loud.
Old Oct 20, 2009 | 09:38 AM
  #25
Lumpy's Avatar
Looks like a good time but if your going to keep playing in the water better get her sealed up.
Old Oct 20, 2009 | 11:00 AM
  #26
yotalaz's Avatar
yeah im going to replace the gear oil this weekend so ill do the breather mod then. any recommendations on viscocity
Old Oct 4, 2010 | 09:50 PM
  #27
yotalaz's Avatar
its a flowmaster from autozone. not sure on the model name. sorry i waited so long to reply but i was going through old posts and i read your question. i ended up adding a resonator in the place where the cat used to be to quiet it down. it was too loud on the hwy.
Old Oct 5, 2010 | 07:29 AM
  #28
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
If anyone's got a hankering for this might I suggest a good going over every weather connector with dielectric grease (though I've heard Vaseline and tampons will work in a pinch)... and a snorkel.
B/c one dip under the airbox and bent valves will cost you a lot more than a $300-$400 snorkel.
And should you get hydro locked STOP. Trying to turn it over and over and over WILL NOT help the situation.
Removing the plugs and turning the engine over with the starter is the proper way of getting the water out.
Then change the oil in it ASAP.... A.S.A.P!!!!
Old Oct 5, 2010 | 07:43 AM
  #29
Swimmerboy2112's Avatar
When the water starts flowin, the engine stops goin.
I don't mess around with deep water. I don't really wanna be replacing an engine any time soon.
Team420
Dec 30, 2015 01:31 PM
Sep 4, 2015 09:27 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
JustToynAround
Aug 19, 2015 11:46 AM
greyheadedguy
Aug 18, 2015 10:40 AM
