Decided to do the head gaskets
Old Mar 11, 2010 | 02:26 AM
  #201
buckz6319's Avatar
have you driven the 3vzeeeee yet?.....is it still running?....
Old Mar 11, 2010 | 06:43 AM
  #202
QuickPaws's Avatar
Originally Posted by budro
That is correct. (btw) I couldn't have completed this project without the help of this forum. Thanks.
Right on. I'm still building a reference section for when I do mine. I owe -alot- to this forum, and I know that when I do mine, I'll prolly have the netbook out there in the garage next to me, all loaded up with YotaTech.
Old Mar 11, 2010 | 06:52 AM
  #203
budro's Avatar
Oh yeah, with a new air filter and spark plugs (the old ones were nasty and gapped at like .07) It seems to be running with a bit more umph. The valves still need to be adjusted so there still might be a little more effeciency left in her, but yeah I've been driving her for the last couple of days without a hitch.
Old Mar 15, 2010 | 09:16 AM
  #204
norcal707's Avatar
hey guys....when you put head gasket do you also put some kind of sealand or what?
Old Mar 15, 2010 | 02:15 PM
  #205
buckz6319's Avatar
no sealant used for the head gaskets, they are made to seal when torqued to specs, although the Heads do require some sealant in KEY Locations around the cam shafts per the fsm
Last edited by buckz6319; Mar 16, 2010 at 02:23 AM. Reason: changed from valve covers to although the Heads do require some sealant in KEY Locations around the cam shafts
Old Mar 15, 2010 | 08:34 PM
  #206
Tubbyfatty's Avatar
.....although the valve covers do require some sealant in KEY Locations per the fsm
Dont be afraid to run a bead of RTV around the whole valve cover. Mine were leaking so bad I would have to add a qt of oil every 700miles.
RTV in the can (pressurized) is amazing.
Old Mar 17, 2010 | 04:10 AM
  #207
budro's Avatar
...although the Heads do require some sealant in KEY Locations around the cam shafts per the fsm
wups, forgot to do that. i had a buddy that tried to convince me to use that spray on sealant stuff. something didn't seem right about it.
Old Mar 17, 2010 | 06:34 AM
  #208
hilandfrog's Avatar
The copper spray on is no good....
I used it on all my "other", read CJ5, chebby rebuilds...
Spray the Head gasket, both sides a few times, let it dry apply???
Is this AFU for Toyota Head gaskets??
Repo
Old Mar 18, 2010 | 01:51 PM
  #209
norcal707's Avatar
hey buckz6319....can you tell me where you got the head gaskets and the bolts....I am having the some problem....dont know from who to order so I decided to ask you..thank you
  #210
norcal707's Avatar
head gasket kit and bolts.
Old Mar 18, 2010 | 03:23 PM
  #211
buckz6319's Avatar
any local auto parts store should be able to help with what you need
I purchased my head gaskets and bolts from O'Reilly's the head gaskets were $60.00 each and the bolts were $30.00 per kit 1 kit per head, however the bolts didn't come with spacers, you will have to reuse you spacers that is on each head bolt.
Old Mar 21, 2010 | 12:47 PM
  #212
QuickPaws's Avatar
You can also check with engnbldr ( http://www.engnbldr.com ) That's where I plan on getting everything from. I think the gasket kit from Ted there is like 139, but they are steelfaced gaskets ( better quality ) and also higher grade headbolts ( you can reuse them, they won't stretch like OEM stuff does )
( this is straight from Ted @ EngnBldr, from an email he sent me when I was asking questions back when I almost had money to start fixing my poor truck.)
Just giving you another option.
Old Mar 21, 2010 | 01:25 PM
  #213
buckz6319's Avatar
I agree there are lots of places to pick up parts....good luck
Old Mar 29, 2010 | 01:30 PM
  #214
norcal707's Avatar
well, i am like 75% done putting it back together, but I broke a sensor so that anyone knows the name or part number so i can look it up online to replace. I dont want to go to the dealer because I know it is going to be more expensive. thank you
Old Mar 29, 2010 | 01:35 PM
  #215
norcal707's Avatar
Attached Thumbnails Decided to do the head gaskets-img00216-20100329-1150-1-.jpg
Old Mar 29, 2010 | 03:05 PM
  #216
buckz6319's Avatar
I think that is a TVV (1) nipple goes to the charcoal purge, and the other nipple to the throttle body on top, if you don't replace it you will get a gas smell that you will not be able to pinpoint.I know this because I broke mine the nipples get brittle over time with the amount of heat in that area
http://www.ncttora.com/fsm/1990-1995...n/evaporat.pdf
I purchased one off ebay used for $15.00 + shipping and it works great
Old Mar 29, 2010 | 03:30 PM
  #217
budro's Avatar
wow big laughs on that. the same thing broke on mine. I got it switched out with another one on ebay. It knocked the build up back a week but definitely worth getting off of ebay. Yeah Toyota sells it for $85 and I got one that came off a supra for around $15 shipping and all.
Old Mar 29, 2010 | 03:45 PM
  #218
buckz6319's Avatar
yep join the club
Old Mar 29, 2010 | 11:49 PM
  #219
norcal707's Avatar
well, I fell better now that I am not the only one to break that piece
Old Mar 30, 2010 | 12:08 AM
  #220
norcal707's Avatar
damn it, I am looking at ebay and cant find one, I appreciate any help finding one for me.
