Decided to do the head gaskets
Old Mar 3, 2010 | 05:32 PM
  #181
budro's Avatar
Well it is about all together. I had to hold off due to a new freind I call bi-metal vacuum switch valve. Till then I'll gather up some new belts and plugs (both were very much so needed) and an air filter. I only wish I did the plugs sooner. The left side seems like a bitch to get at with any kind of extension, but yeah just about done.
Old Mar 4, 2010 | 02:31 AM
  #182
buckz6319's Avatar
way cool....thanks for the update...the 3vze by far has been the worse engine I ever had to work on! and I have had over 100+ autos, trucks, motorcycles, atvs......in my life time
Old Mar 6, 2010 | 02:40 PM
  #183
budro's Avatar
So I got it all back together and tried to crank and the battery is dead, just a bunch clicking sounds is all I get today. I have a bad feeling about this. I tried to jump start and even after about 15 minutes of charging it sounded like it was having a hard time turning the engine. I guess I'll get a new batter and keep my fingers crossed.
Old Mar 6, 2010 | 03:12 PM
  #184
Tubbyfatty's Avatar
Did you turn it over by hand after putting it all back together?
Old Mar 6, 2010 | 03:40 PM
  #185
budro's Avatar
yeah when I was checking the timing.
Old Mar 6, 2010 | 03:55 PM
  #186
budro's Avatar
hmm not after assembly though. I'll go out tomorrow and do that.
Old Mar 6, 2010 | 04:03 PM
  #187
buckz6319's Avatar
looks good!...a BIG STEP! to over come is putting all the pieces back together...I know it will run again
Old Mar 7, 2010 | 05:38 AM
  #188
budro's Avatar
So I put in a new battery and nothing. It'll crank like mad now but besides the random backfiring it won't start.
So now starts the part where I find out what I did wrong.
Old Mar 7, 2010 | 05:42 AM
  #189
buckz6319's Avatar
backfiring maybe a sign of a timing issue, did you install your dizzy correctly?....all timing marks lining up correctly
Old Mar 7, 2010 | 06:26 AM
  #190
budro's Avatar
yeah looks like I am going to have to go back in and check that timing out again. Tuesday is the next day I have off so I'll double check my work then. For now I don't think I can even think about turning another wrench. Maybe the process of going crazy thinking about it will get me to go out there again within the next couple of days but till then
Old Mar 7, 2010 | 07:34 AM
  #191
buckz6319's Avatar
I just hope you have warmer weather that I did, when you started your project.I froze my ass off replacing my head gaskets...........I'm looking forward to your next update
Old Mar 7, 2010 | 08:18 AM
  #192
1990yota-pickup's Avatar
after to set your timming rotate your engine over 3 cycles byhand to see if you sett it right.
Old Mar 7, 2010 | 03:26 PM
  #193
budro's Avatar
not once or twice but thrice? that only makes sense. Just to make sure that it sets I guess huh. Yeah I rotated it but only one cycle. I thought that would be enough. I remember earlier in this post that you (buckz) had to dig back into as well because of that damn belt falling off a couple of teeth on the cam sprocket. yikes. So yeah on monday after work I'll set the #1 on tdc and double check to see if I got the distributor right, and if I did then back into it I'll go.
Old Mar 7, 2010 | 05:11 PM
  #194
Tubbyfatty's Avatar
Agreed.
Old Mar 9, 2010 | 10:13 AM
  #195
budro's Avatar
well this is what I saw when I got the timing belt cover off and aligned all the markings. (not where the rotor is pointing)
I don't know how it happened but it is all back together and RUNNING
Old Mar 9, 2010 | 11:49 AM
  #196
buckz6319's Avatar
Old Mar 10, 2010 | 10:17 AM
  #197
QuickPaws's Avatar
Dude, I can only hope that that's the only problem ( if any ) that I have when I do mine! Cake fix! Grats on it too!
Oops, I meant to clarify, in that pic you snapped of the Dizzy, that SHOULD actually be about 180 from where it is ( give or take ) right?
Old Mar 10, 2010 | 11:45 AM
  #198
budro's Avatar
That is correct. (btw) I couldn't have completed this project without the help of this forum. Thanks.
Old Mar 10, 2010 | 03:32 PM
  #199
did the 3 time rotation dothe trick?
Old Mar 11, 2010 | 01:17 AM
  #200
budro's Avatar
No, I must have moved my engine before I installed the rotor assembly.
