Dash/instrument lights not working. running lights work correctly.
Old Dec 23, 2014 | 06:09 PM
Izthizcheeze's Avatar
Hey guys,
I've had my 92 runner for a little over a year now. I bought it for a good price and had to rebuild the engine (burnt valve). Anyways, to get to the beef of this, my dash lights haven't worked since day one. I've check the fuse and jumpered the rheostat/dimmer (which blew the tail fuse and didn't make the lights work). I'm at a loss now, and would appreciate any help you can give me. I've also read about blown dash lights, but it is also my A/C lights and whatnot. Thanks in advance
Old Dec 23, 2014 | 09:07 PM
dropzone's Avatar
Fossilized
Bust out the wiring diagram, DMM and test light. Probably a loose wire. Dash lights are on the same circuit as your a/c cluster..
Old Dec 23, 2014 | 11:16 PM
wyoming9's Avatar
Red face
Since they never worked it might be all the bulbs are burnt out .
Now of course the fuse will open if you tried to bypass the rheostat with the circuit energized what your doing is just taking system voltage to ground .
It then draws more current then the fuse allows.
Now since all the switch lights on the console and dash also run on the same circuit do any of these work??
Old Dec 24, 2014 | 12:42 AM
RAD4Runner's Avatar
Yes, all of the above. Report back and we'll go from there.
Old Dec 24, 2014 | 11:58 AM
None of the console lights work. The only thing that illuminates is the check engine light, etc. Etc. I'll get the wiring diagram out. I jumped the dimmer because that is what I read would determine if I need a new dimmer or not. Thanks
Josh
gillesdetrail
Nov 19, 2019 12:56 PM
JF9243176
Oct 8, 2017 04:21 AM
torgeir
Jun 25, 2015 05:26 AM
gog1968
Jun 22, 2015 05:55 AM
Corey
Jun 25, 2002 11:13 AM
