cv shaft replace or not
Old Mar 15, 2009 | 08:49 PM
94exblack's Avatar
I am in the process of istalling 4.88s in my pickup its got the basic 4 inch lift. Im wondering if while I have everything apart if I should go ahead and spend the money new shafts or if I would be better off leaving the old ones in there the boots look good and Ive never had a problem with them before I believe they are factory parts. Just running low on funds and the extra 140 or so could be spent elsewhere.
Old Mar 15, 2009 | 08:55 PM
874runnersr5's Avatar
hm, if the boots havent worn down from the 4inch lift. Then they should be fine.
Old Mar 15, 2009 | 09:01 PM
94exblack's Avatar
I thought they should be ok, and The truck could seriously use some exhaust work thanks
Old Mar 15, 2009 | 09:03 PM
Yeah, as long as the boots arent cracking or have that old rubber texture to them you should be fine. Do you have manual hubs to?
Old Mar 15, 2009 | 09:06 PM
abecedarian's Avatar
yup... if it isn't broke don't fix it... unless you have the coinage.
in general, if the boots aren't compromised / squirting grease, and it's not clicking, grumbling or vibrating, the joint is fine.
Old Mar 15, 2009 | 09:07 PM
Plus, if you do want to change them, just rebuild them. Probable cost 40$ for both sides, all you need is cv grease,new boots, and alot of towels.
Old Mar 15, 2009 | 09:47 PM
iamsuperbleeder's Avatar
Originally Posted by 874runnersr5
...and alot of towels.
nah, just a couple cans of brake cleaner and a garden hose with a spray nosel
Old Mar 16, 2009 | 08:32 AM
OutlawMike's Avatar
If you are going to rebuild, Downey makes neoprene boots that supposedly will take more angle without ripping.
I have no experience with them, but have thought about picking up two sets.
Mike
A2theK
Jan 10, 2016 10:18 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
akaphilly
Jul 9, 2015 02:34 PM
