CV Boot/Halfshaft Replacement Help! 1993 4runner
Old Nov 23, 2007 | 05:30 PM
JonnyBoy's Avatar
The part about knocking out a couple of the studs was to clear the diff side with removal. I didn't, but it woulda been better, I used a pickle fork to separate the lower ball joint, then unbolted the upper ball joint from the control arm. It made it, but I think it'd have been easier to knock a couple studs out an replace 'em with bolts. I'm wishing I had because I didn't grease those bushings an now my driver's side axle's makin noise. Oops. It's all possible, just keep at it.
Old Nov 24, 2007 | 06:58 AM
dirtyXplorer's Avatar
Disconnecting and connecting ball joints dosen't mess with the alignment, does it?
Old Nov 24, 2007 | 12:53 PM
HAHA I win!!! (notice, no CV axle)
since everyone loves pictures here is a few...
While the old one was off I noticed some wear spots on the back of the spindle. Sine I drive it every day I had to put the new shaft in there. Will this be a problem? I also put some grease on there, hoping it wont get worse.
Here is a picture looking out with the halfshaft removed. (Camera phone=crappy pictures)
BTW, Putting the new ones in is alot easer than taking the old ones out
While I was down there I also replaced the sway bar bushings with energy suspension ones.
Weidle
Jan 21, 2019 05:39 AM
voiddweller
19
May 2, 2016 09:10 PM
Colington
Oct 12, 2015 05:41 PM
Valvoman
Jun 28, 2015 02:45 PM
odonekanobe
Jun 26, 2015 02:27 PM
