Cut Engine Wiring Harness...Is this Common?
Old Jun 17, 2014 | 05:28 PM
nisif's Avatar
Hello all,
I just recently bought a 89 Toyota Pickup 4WD with a 22re from a friend with a bad engine (rod knock). I've drove the truck before and it ran great before the engine failure.
So I picked up a good 22re complete engine locally and I'm in the process of swapping engines.
This is what I found odd. The engine wiring harness leading to the ecu plugs have multiple cut wires although the truck still ran well before. Just wondering if the truck may have came with a different engine from the factory, 22r maybe??
Also the engine i bought has a complete uncut wiring harness although the ecu plugs are different shapes so it won't plug into the 22re ecu I have now.
Originally I wanted to use the unhacked harness but since it won't plug into the ecu that won't work unless I use the matching ecu.
I'm just looking for suggestions before I install the new engine in. I guess I could keep it simple and use the hacked harness since it worked before and transfer it to the new engine.
Attached Thumbnails Cut Engine Wiring Harness...Is this Common?-20140617_011449-1-.jpg
Old Jun 17, 2014 | 05:43 PM
nisif's Avatar
Here are some pics...
Harness of the engine in truck...
Harness on the new engine...
Old Jun 17, 2014 | 06:10 PM
thefishguy77's Avatar
That would be the simplest way by using the hacked harness.
Old Jun 17, 2014 | 11:07 PM
wyoming9's Avatar
Red face
You have no idea of what year the used engine came out of??
I would just get the ECU for the used engine and be done
I can only guess the things that don`t work from all those cut wires.
Till you remove the good harness and install the cut one it will be real lucky if it runs or would be if it is mine.
Old Jun 18, 2014 | 12:09 AM
vital22re's Avatar
totally a bro
google says the ecu is from 90-93 trucks/4runners.
Old Jun 18, 2014 | 09:44 AM
nisif's Avatar
Ok, the new engine and harness is from a 91. So I guess I need a 91 Ecu to clean this up. The Ecu I have now won't plug into the new harness
Did the 89 pickups come with 22r engine from the factory?
Old Jun 18, 2014 | 12:20 PM
wyoming9's Avatar
Red face
I think it was still an option off the top of my head can`t say for sure.
Old Jun 18, 2014 | 03:44 PM
osv's Avatar
osv
i'm guessing that carbed vs. efi harnesses would be radically different, so much so that no amount of hacking could really make up the difference... it's probably not an issue.
so both harnesses plug into the sensors on the new engine correctly? and the airbox as well?
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
Gamble_STi
Jul 7, 2015 07:54 PM
toyota32
Jul 6, 2015 05:42 PM
