crazy smoke, little fluid loss
Old Jul 30, 2008 | 09:55 AM
idanity's Avatar
fired up my 3ve yesturday.
added less then a quart of water after letting it idle for about 35 minutes.
never overheated, but its blowing white smoke.
not sweet smelling
oil is perfect.
coolant is still red..
wtf??
Old Jul 30, 2008 | 11:11 AM
camo31_10.50's Avatar
i've heard the red coolant is only to be used in certain vehicles it ate through some lines on somebody's car around here..thats where i heard it from...also heard from a dealer that its only to be used if your vehicle calls for it..its a little different than the regular green stuff...of course it could be the same thing..just made by a diff company..that put red dye in it..idk...the red stuff we got around here (the name is not coming to me at the moment) is bad news for anything other than like the NEW cars and trucks...just a thought..probably a stupid post here by me.lol..just seen the red coolant..remembered the hell one of my friends went through when it effed up some stuff on his car...
Old Jul 30, 2008 | 11:22 AM
Jay351's Avatar
The red coolant is infact OEM toyota brand coolant. You are suppost to run it to keep electrolisis down. Green stuff is junk.
Old Jul 30, 2008 | 01:57 PM
idanity's Avatar
okay, i got good coolant,
but what about this smokey stuff.
why would it smoke like a coal factory, and not lose coolant or oil...
and have both coolant and oil look great (recent oil change)
cracked cylinder>
head gasket>
warped head>
water PUMP >
starts right up, and drives, but is smokey, plenty of power.
help
Old Jul 30, 2008 | 02:07 PM
Jay351's Avatar
Does the smoke decrease after the truck is warmed up?
Have you done a cooling system pressure test?
Old Jul 31, 2008 | 11:43 AM
idanity's Avatar
good call
never heard of cooling pressure test.
and smoke did decrease after i poured stop/smoke in the coolant.
Old Jul 31, 2008 | 03:38 PM
superjoe83's Avatar
i really hope you didnt do what i think you did....
Old Jul 31, 2008 | 04:44 PM
DeathCougar's Avatar
Are you loosing coolant Dan?
Sounds to me like the dreaded 3VZ head gasket. My parents 95 did the exact same thing.
Old Jul 31, 2008 | 07:21 PM
idanity's Avatar
i know enough that smoke is bad.
but, i dont get it.
i dont smell sweet-ness (coolant) and its not depleting.
i know its gotta be either head gasket, or waterpump...
but
after 35minutes...not a cup of water is needed...wtf..?
anyways
is headwork the best thing...?
its summer, and after this weekend (pitting for the pro3) i will be able to tear it apart and replace it.
but
i want to know,
should i just trade it in ? or fix it ?
Old Jul 31, 2008 | 07:52 PM
Well, have the normal tests done. Compression, leak down, etc etc. That will give you a baseline to start with.
he's gone
7
Dec 3, 2019 07:08 AM
JaredL
Mar 28, 2016 09:08 PM
TACOJO
Nov 27, 2015 05:26 PM
old87yota
Sep 9, 2015 12:39 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
