Crap! Head Gasket Giving Up the Ghost...
Old Mar 9, 2007 | 06:58 AM
  #61
TNRabbit's Avatar
Nobody...?
Old Mar 9, 2007 | 10:42 AM
  #62
thook's Avatar
Wish I could help you TNR, but that's outta my league. I'll root for speedy assistance, though!
Old Mar 10, 2007 | 12:10 PM
  #63
TNRabbit's Avatar
Well, got the heads pulled today. Here's a link to the all the pics so far:
http://www.putfile.com/tnrabbit/images/89906
And here's the short version...got the pulleys off the main shaft for pulling the oil pump later:
and took out MOST of the oil pan bolts. How the heck do you get the ones in back out?!?
had to use FOUR socket extensions & my torqure wrench to get these effers off:
this little sucker was hiding under a shroud under the intake manifold; you CANNOT get the heads off with manifold intact without pulling it and the following ones (10 mm, five in all):
and this one is hiding on the backside of the right head:
Right cylinder bank:
and Left cylinder bank:
See any evidence of blown headgasket here?
Or here?
Right bank head:
Left bank head, #2 cylinder:
No carbon buildup to really speak of:
And I'll be darned if I can see any evidence of a blown head gasket or obviously cracked head!!
Here's some pics of the #2 cylinder, cross hatching intact--woo hoo!
Does anyone see any reason why I would have coolant in the #2 cylinder? Maybe crack head up behind the valves/guides?? Any other ideas?
BTW; all the other cylinders looked like this; a little toasty?
Old Mar 11, 2007 | 09:34 AM
  #64
TNRabbit's Avatar
Here's the culprit:
the dark, rusty looking spot on the HG. Everything else looks good.
I've sent an oil sample to Blackstone Labs; if it doesn't show any abnormal bearing wear, I'm going to stick with my original plan to change out both HGs, oil pump, & timing belt. If there are bearing issues, I'm going to go with the complete engnbldr rebuild. Wish me luck!
Old Mar 20, 2007 | 04:40 PM
  #65
TNRabbit's Avatar
Big day! Got my Blackstone Labs report: They said there was some wear on the bearings & cylinders, probably caused by the antifreeze in the oil, but that the oil still had a good amount of wear protection in it (with 8500+ miles!). Looks like I can run my Mobil 1 for 10,000 miles if I change the filter @ 5k.
Ordered a spindle nut kit, clutch foot cover, and shifter bushing from MarlinCrawler.
Ordered a machinist's tool set from Sears: http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Ordered the Master Engine Kit from Ted @ engnbldr.com; he was extremely helpful, talking engine stuff with me for a good 15 minutes before I ordered the kit, PLUS they are having a SPRING SALE (!) so I got the entire kit delivered for only $378.00...WOO-HOO!! (a savings of $36.00)
Ted thought my increased compression readings were probably from the head being machined when the HGs were done in 1998 (before I bought the truck). No way to know for now.
I'm waiting on delivery of an engine hoist from Northern Tool on Friday. I'll have the engine out before I head for Puerto Rico on Sunday!
Old Mar 20, 2007 | 04:54 PM
  #66
justinking060310's Avatar
Did Ted say anything to the positive or negative about the higher compression? Will that affect future head gasket issues....
that machinest set looks nice --
Have you dropped your block and heads off at the machine shop yet? whats the word - I need all the info i can get here....
Kat
Old Mar 20, 2007 | 05:03 PM
  #67
TNRabbit's Avatar
Ted said I'd have to ensure the machine shop double checks the decking for both heads & block to ensure too much hasn't been taken off. I was running super unleaded with no issues before. I'll be using Ted's 10.9 headbolts. I think most HG issues are from folks replacing them without having the head/block checked; Ted agreed with me on that.
Thanks--I can't wait--I love new toys! by the time I get finished, I'll have enough tools to open my own shade tree mechanic business! check the first pics of the air compressor I purchased from Northern Tool; I really got lucky there and bought it when they had FREE SHIPPING (it weighs 385 lbs!)...
Have you dropped your block and heads off at the machine shop yet? whats the word - I need all the info i can get here....No, I won't have the engine out until Friday--"I'm waiting on delivery of an engine hoist from Northern Tool on Friday."
Kat
Old Mar 20, 2007 | 05:15 PM
  #68
Did you get the fancy red one like i have? its a life saver sometimes - I used it to unload my new 8" jointer yesterday (700 lbs) **see how i stuck a tool gloat in there**
What kind of compressor is that? i got the IR 5s5(something like that) from Northern in Nov or Dec... I am loving air tools! I reccomend an AirCat NitroCat if you need an impact gun....
Sorry to get off topic but you started talking about tools!
kat
Old Mar 20, 2007 | 05:24 PM
  #69
TNRabbit's Avatar
Did you get the fancy red one like i have? its a life saver sometimes - I used it to unload my new 8" jointer yesterday (700 lbs) **see how i stuck a tool gloat in there** Yep, same one!
What kind of compressor is that? i got the IR 5s5(something like that) from Northern in Nov or Dec... I am loving air tools! I reccomend an AirCat NitroCat if you need an impact gun....Have had a full set of impact tools for a couple of years; I was running an old 20 gallon Craftsman electric (220) compressor & recently sold it on eBay to upgrade. I got the NT w/the Honda 13 hp engine, 26 CFM @ 120 PSi, max 175 PSI! **more tool gloat** I'm with you on the Snap-On torqure wrench...buy to last.
kat
Old Mar 20, 2007 | 05:28 PM
  #70
I guess your ___ is bigger than mine - I mean your compressor blows more than mine - I mean...
I only have 5hp and 18 cfm at 90 psi -- and i thought i went overboard -
Nice compressor you have there though... What kind of impact are you using?
Old Mar 20, 2007 | 05:46 PM
  #71
TNRabbit's Avatar
ummm.....oooookaaay....*must...control.....urge... ..to make sexual inuendo comments*
Most of my air tools are HD Campbell Hausfield; not the best, but I got them SuperCHEAP on eBay. I have a really nice Chicago Pneumatic air drill and a Craftsman Professional Air Grease Gun as well. *brag*
Old Mar 20, 2007 | 05:58 PM
  #72
i have been wondering who buys those air grease guns -- now i know...
Old Mar 20, 2007 | 06:06 PM
  #73
TNRabbit's Avatar
It makes short work of the MULTITUDE of grease fittings on my truck...
Old Mar 21, 2007 | 12:09 AM
  #74
TNRabbit's Avatar
Oh yeah-I forgot! I also sent my injectors off to witchhunter.com..
Old Apr 3, 2007 | 03:14 PM
  #75
TNRabbit's Avatar
Well, I'll be coming back to MD from San Juan tomorrow! (yuck)
SO, I'll be pulling my engine out this weekend. Until then, here's some pics from San Juan to keep everyone entertained:
Over the city (from a helicopter):
Some views of the airport & rain forest in the background:
And the beach:
I actually hiked to the top of this mountain last Saturday:
  #76
TNRabbit's Avatar
How many people hijack their OWN thread?!?
Old Apr 3, 2007 | 03:18 PM
  #77
i like the pictures, what do you do for a living?
Old Apr 3, 2007 | 03:22 PM
  #78
TNRabbit's Avatar
You have PM.
Old Apr 4, 2007 | 04:24 PM
  #79
TNRabbit's Avatar
Got my precision tool set & engnbldr kit:
Gonna get my hoist together & pull the engine tomorrow.
Old Apr 4, 2007 | 04:39 PM
  #80
nice presents from ted -- I should have a similar box on my doorstep tomorrow!
Do you have some more information about the tools? What all can you do with that set?
