Crap! Head Gasket Giving Up the Ghost...
Old Jun 8, 2007 | 02:13 PM
  #241
TNRabbit's Avatar
The diffs have a breather at the top just like the tranny & transfer case. That nipple is different from the breather--the breather is right next to the shifter.
Old Jun 8, 2007 | 02:39 PM
  #242
mudbutt's Avatar
Originally Posted by TNRabbit
I'm having an odd thing happen; when I rev the engine to just over 4000 rpm & shift, I get a "buzzy" feeling in the clutch pedal & a simultaneous buzzing sound from what sounds like the drivers side in front of the firewall. It doesn't happen escept when I have the clutch pushed in, which leads me to believe it is the throwout bearing. But it's a MarlinCrawler & brand new, so I don't think that's it. Is there something about the clutch linkage that could cause a similar vibration?
Is it possible that you have the drivers side engine hook on backwards? I've seen this where they rub on the hard brake/clutch lines when they are reversed.
Old Jun 8, 2007 | 02:41 PM
  #243
mudbutt's Avatar
Originally Posted by 2WDoffroadx
That nipple on the tranny is a breather. Your differential should have it, too.
Close, it is the hose/nipple that the t-case vents through because it doesnt have it's own breather. It vents through the transmission.
Old Jun 8, 2007 | 05:22 PM
  #244
TNRabbit's Avatar
Thanks! I'll check it out tomorrow.
Old Jun 9, 2007 | 11:27 AM
  #245
TNRabbit's Avatar
This will probably be my last post in this thread. I drove the truck from southern MD to near Harrisburg, PA, this morning to pick up a lawn tractor and came back with 1000 lbs of tractor in the back end! It ran great. I even shot a short video of hitting 90 mph on level ground with the tractor in the back. I could've done more, but didn't want to push my luck. Here's pics/video:
Squattin' a little, eh?
I managed to rub a little bit with the load! Where are those helper coilovers?!?
And here's the load:
Here's the VIDEO:
Click here to watch Hitting-90-mph-in-the-Yota-w1000-lb-load
Old Jun 9, 2007 | 02:10 PM
  #246
Guardian_Saint's Avatar
wow fast ehh, wonder why it still been call a 3.SLOW.
Old Jun 9, 2007 | 07:57 PM
  #247
kevinkal's Avatar
Grats on getting your truck up and running well!
Old Jun 9, 2007 | 08:39 PM
  #248
spanish-road's Avatar
damn you know you missed something when you have two bolts left and some body-armor you have no idea how it goes on.
Old Jun 10, 2007 | 02:07 AM
  #249
TNRabbit's Avatar
Well, I went thru a LOT of parts during all this...those were some of the first that came off.
Old Jun 11, 2007 | 04:21 AM
  #250
TNRabbit's Avatar
I just wanted to say a great big Thank You to everyone who helped me out on this project. At times I thought it would never end, but now it's done & lil' red is running great again! I hope folks will be able to use my trials & tribulations to their advantage should they ever decide to dig into their Yota. if nothing else, it has been an entertaining story!
Special thanks to Kat (justinking060310), Bumpin' Yota, thook, MarlinCrawler, engnbldr, and WabFab!!
Old Jun 11, 2007 | 08:16 AM
  #251
Blurr's Avatar
good work, Rabbit. reading this thread has given me hope in my top-end rebuild.
Old Jan 4, 2008 | 06:17 AM
  #252
TNRabbit's Avatar
Follow thread on this: https://www.yotatech.com/forums/f116...perate-123651/
Old Jan 4, 2008 | 06:31 AM
  #253
mt_goat's Avatar
Oops, there goes that hope
So what are you driving while you wait Rabbit?
Old Jan 4, 2008 | 06:37 AM
  #254
TNRabbit's Avatar
Bought a '95 Ford Probe with 225k miles for $1000. Runs great. Feels like I'm driving a damn formula one next to the truck!
Old Jan 4, 2008 | 06:57 AM
  #255
mt_goat's Avatar
Sounds good, I still have the 95 Taurus I bought to drive during my swap. It has a little coolant leak again though. I'm always fixing something on it but at least the headgaskets are holding. It has cast iron heads (a good match for a cast iron block IMHO) and a timing chain so it may go for a long time. It gets 30 mpg on the highway with a tailwind LOL. Plus it may be a classic in 50 years
Old Jan 15, 2008 | 02:05 AM
  #256
TNRabbit's Avatar
That's funny! I always wanted one of the Taurus SHOs with the Yamaha 5 valve/cylinder engine. Kickass engine.
FYI to all: I've found an engine to replace the one currently in my truck; refer to the followup thread:
Old Mar 1, 2008 | 04:54 PM
  #257
cdphillips60's Avatar
I have indications of water in the oil, but little, if any loss of coolant, or oil in radiator. I sent my oil to Blackstone Labs for analysis and they confirmed glycol in the oil and metals associated with bearing wear. Given that the motor has close to 180K mi. on it and the history of bearing wear with the motor, I decided to do a rebuild on the motor. I can't see going to this level of work and not taking care of old main seal or having premature failure because I didn't mill the block. While I can't afford to swap to another motor, I want to rebuild it prior to crankshaft or other damage.
I was very pleased with the service that Blackstone provided and the insight the test gave me. For a little over 20 bucks, I feel fairly confident that now is a good time to pull my motor...
IMHO
Chris
Old Mar 26, 2008 | 08:29 AM
  #258
TNRabbit's Avatar
Damn; deal with the engine fell through. I guess I'm just going to have to break down & install that HG I bought!
Old Mar 26, 2008 | 09:58 AM
  #259
91Toyota's Avatar
Your name seems really familiar...are you also on TN?
Old Mar 26, 2008 | 05:24 PM
  #260
TNRabbit's Avatar
Yep; for at least 3 years now...!
