Crank shaft front seal numbers
Old Sep 11, 2013 | 06:05 PM
davis131's Avatar
I just got my 91 xtracab back on the road after a lot of work and mods and it's still leaking a lot of oil,I replaced the front crank seal (number 2 )and still seams to be leaking from there.I know I saw a while back where there were 3 choices for front crank seals for the 22re a thin,thicker and thickest seal but can't find the numbers.I've used the one that came with the original timing kit then I used a NAPA 17758 and I think theres one more a very thin seal,the parts guys are not much help,hopefully someone hear has used it??
Old Sep 11, 2013 | 08:11 PM
Kiroshu's Avatar
If you are constantly replacing front main seals because they keep leaking...
I would suspect a worn Crankshaft pulley/Vibration Damper.
-They sell repair kits, and some timing cover gasket kits are sold with repairs kits.
Or a replacement pulley is also available.
Old Sep 12, 2013 | 04:13 AM
davis131's Avatar
I never thought of that,I'm going to do some searching,Thanks So much Kiroshu
Old Sep 12, 2013 | 07:07 PM
Kiroshu's Avatar
No prob.
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
jerusry
Oct 19, 2015 05:28 PM
redneck17
Jul 17, 2015 07:44 PM
andrewtexas123
Jul 14, 2015 04:29 AM
