crank but no spark
Old Oct 6, 2024 | 01:49 PM
Denton1426's Avatar
crank but no spark
I have read a lot of Forums and FSM about my issue. I have a 91 3.0 3vze truck had blown head gasket. I replaced engine with a rebuilt long block. I have checked distributor (Good,) I have CEI with codes 12, 31, 14. I have !2v at Igniter and coil. I have replaced COIL with new. No change. I can remove distributor and spin the shaft with my hand I have good spark, once installed back in the engine I have no spark when spinning the engine over with starter. I have checked ignition. I have no idea where to go from here. It don't seem like ECU because I have CEI and voltage at the igniter. But I'm no expert either. Any help would be greatly appreciated. I don't want to just throw money at this to figure out what is going on. HELP PLEASE!!
Old Oct 6, 2024 | 01:57 PM
Robert m's Avatar
With the distributor installed, does the rotor spin when you crank the engine?
Old Oct 6, 2024 | 01:59 PM
Denton1426's Avatar
Yes rotor turns!
Old Oct 7, 2024 | 03:16 PM
osv's Avatar
osv
can you clarify that?
fwiw a similar problem: https://www.justanswer.com/toyota/2h...-no-spark.html
Old Oct 7, 2024 | 04:03 PM
Denton1426's Avatar
I remover the distributor from block, and spin the shaft with hand! With distributor plug the harness it will fire and injectors will open and close. Hope that makes sense.
Old Oct 7, 2024 | 04:25 PM
osv's Avatar
osv
thx, that's an interesting approach.
in that link i posted, it was an airflow meter problem.
Old Oct 7, 2024 | 04:27 PM
Denton1426's Avatar
Please explain! I have tried everythiing
Old Oct 8, 2024 | 12:29 PM
osv's Avatar
osv
you'll have to read the posts in the link, it has a lot of troubleshooting in it
Denton1426
Oct 6, 2024 01:44 PM
Rdin
Aug 11, 2023 01:55 PM
Panorama
May 15, 2021 09:49 AM
Gevo
Feb 2, 2014 09:01 PM
Pops57817
May 29, 2011 01:52 PM
