Cracked head between valves 3vze, need input
Old Feb 26, 2010 | 10:48 AM
Larryb's Avatar
91 4runner blew a headgasket. Removed the heads this morning and found one of the cyl's with a horrible looking crack between the valves(see pics). I have a appt on monday to take the heads in to be pressure checked and surfaced but not sure if this head is toast or not?? Any opinions?
Old Feb 26, 2010 | 10:55 AM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Get out your favourite milkfat-based spread and have some breakfast.
Old Feb 26, 2010 | 11:33 AM
abecedarian's Avatar
I would not expect that head to make a full recovery.
Old Feb 26, 2010 | 11:39 AM
DeathCougar's Avatar
The long and short of it is, that head is junk.
You have to replace the head. There is no other way around it.
Old Feb 26, 2010 | 11:46 AM
OutlawMike's Avatar
I see a future for that head casting in aluminum cans. In six months I might be drinking my favorite beverage from a can made from that aluminum.
Old Feb 26, 2010 | 12:02 PM
OutlawMike's Avatar
Another guy just posted up with some head problems, he says that he is going to get a set of reconditioned heads for $535 from National Cylinder Head.
Seems like a great price, maybe too good to be true. I paid close to 1k to have mine reconditioned in town a few years back. That was with new valves, valve job, but re-using the cams.
Good luck.
Old Feb 26, 2010 | 12:09 PM
neockder's Avatar
Definitely need a new head.
Or.. find a used motor with low miles and swap the whole thing in.
Old Feb 26, 2010 | 12:33 PM
Larryb's Avatar
ugh....life sucks
Old Feb 26, 2010 | 12:53 PM
Larryb's Avatar
I have located another engine locally with a 157,000 miles before a rod bearing went bad. I am thinking of buying this engine to salvage the heads. What is the average price of a valve job on the 3.0 heads?
Old Feb 26, 2010 | 07:59 PM
bugs1961's Avatar
I paid $200 a year and a half ago per head for:
new exhaust valves
new exhaust guides
new exhaust seats
intakes reground
head surfaced
all new valve seals
valves adjusted with proper fitting shims (I gave them the heads with the cams in place so they could adjust the valves)
Old Feb 27, 2010 | 05:48 AM
Larryb's Avatar
Cool, i think i have found another set of heads, actually a whole engine that has no head gasket problems. Wish me luck this time around
Old Feb 27, 2010 | 05:57 AM
1stgen4gunner's Avatar
I think this has been said plenty of time (I haven't read any of the other posts) buuuut.......HEAD IS SHOT BROTHA!!!!!!
Old Feb 27, 2010 | 11:03 AM
Tracey98277's Avatar
Good luck.
WHAT? i paid $680 for mine to be worked on with new valves and cams.
Old Apr 17, 2010 | 06:53 AM
Larryb's Avatar
Update - Located a used set of heads and took them in for a valve job and to be surfaced. Replaced the timing belt, idler pullies, water pump, cap, rotor, wires, etc. Took it in to be smogged and passed with flying colors, majorly relieved. All is good now.
the1998sr5
15
Jul 14, 2020 08:35 PM
coleypull15
Nov 3, 2015 07:41 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
