Coolant temp sensor broke
Old Jun 2, 2012 | 03:12 PM
HAWAIIANSTYLE's Avatar
i was trying to install a new coolant temp sensor in my 94 runner but as i was removing the old one, it broke. the threads of the old sensor is stuck in the housing. how do i get the threads out so i can put the new sensor in?
Old Jun 2, 2012 | 03:57 PM
StewsRunner's Avatar
Is the sensor still in there? Did you only break the plastic connector? I broke mine the other day, I swear a fly landing on it could break that thing. . .
Old Jun 3, 2012 | 11:15 AM
the entire bottom half of the sensor got stuck in the threads
Old Jun 3, 2012 | 01:32 PM
wilywin's Avatar
I got a 86 4x4...22re..! Where is the coolant temp sensor located???? Be having a heck of a time with overheating problems! New head last summer, new thermostat, new clutch fan, brand new radiator....water pump working fine! Coolant temp sensor last option! wheres it located?
Thanks
wilywin@aol.com
Old Jun 3, 2012 | 01:49 PM
I think it's called the coolant manifold, in the 3.0 it's between the engine and the firewall
Old Jun 3, 2012 | 02:02 PM
mldave's Avatar
wilywin,on my 86 truck it's below the t-stat housing..the green sensor on the right.
Old Jun 3, 2012 | 09:53 PM
wilywin's Avatar
whats the other sensor? (left) ? Also...not to sound dumb and obvious, but how can you tell if that sensor is bad? What goes wrong on the truck when it goes bad? I am having some overheating problems and have replaced everything under the sun! New head, rv cam, timing set, clutch fan, radiator, thermostat. Thing still gets hot??? And the gauge only seems to work speradically!
Thanks
Old Jun 4, 2012 | 03:20 AM
mldave's Avatar
The black plug is the cold start injector time switch.The wires on these sensors and switches are often very brittle.My temp sensor wires broke two different times on my 86 truck,As far as the overheating,I don't have a clue.Someone on this board will know.
Old Jul 26, 2012 | 10:50 AM
nickxrunner's Avatar
Any updates on how you got the threads out??
oldirtydirt
Feb 23, 2020 09:30 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
