Coolant Sensor Location
I am having a really hard time locating the coolant sensor.
I have looked at several diagrams, but can't find any for my '88 3.0. I have a bad feeling it's under the intake manifold which hovers on top of the whole engine. I really don't want to take that apart just to get to a sensor to test/replace it.
Just FYI, I am testing if the sensor might be causing my lack of overdrive. I get overdrive after a while on the freeway, but it seems to be taking longer and longer, and it's killing my MPG.
So if any of you could in detail point out where the sensor is, or ideally post a picture, I would greatly appreciate it.
I have looked at several diagrams, but can't find any for my '88 3.0. I have a bad feeling it's under the intake manifold which hovers on top of the whole engine. I really don't want to take that apart just to get to a sensor to test/replace it.Just FYI, I am testing if the sensor might be causing my lack of overdrive. I get overdrive after a while on the freeway, but it seems to be taking longer and longer, and it's killing my MPG.
It is the sensor with the light grey end in MT Goat's picture above. I have a new sensor sitting on my work bench waiting to go in. The problem is whenever I have time to work on it, the engine is hot and difficult to work in that area. I'm hoping it will solve all my problems as well. Although mine are idle speed problems.
Just so you know, there is a quick test for it in the FSM. Mine didn't check out too well.
Jason
Jason
Jason
Jason
BTW, the only FSM I could find online was for the 22XX engines, but nothing on the 3.0 Anyone know where I can find a copy?
Here's the 93 FSM it has both engines:
http://personal.utulsa.edu/~nathan-b...fsm/index.html
If you have a hard time reaching the sensor you could always take the hood off and get it out of the way.
Has anyone had this sensor out before? The new one I got from Toyota has a probe on it about 1 1/2" long. Do I need to drain some of the coolant or is it located high enough up that no coolant will pour out?
JAson
JAson
mine turned out to be bad and was sending incorrect signaly to the temp guage.
https://www.yotatech.com/forums/f116...hlight=coolant
ttyl
ttyl
ttyl
ttyl
Well an update for you all, I disconnected the sensor wire, and the temp gauge stayed at 1/2. I thought maybe I didn't have the right sensor, so I tried the same with all three sensors hanging out back there, no change. From the diagram in the book, it shows the sensor on the driver's side. But I wanted to be sure. This was all with the engine warmed up, which really sucks working back in there, BTW.
So does this show that my actual gauge is bad? If so, how easy is it to find/install a new gauge?
EDIT: I am re-reading the posts here, and am now confused. There is a Temp sensor and a Temp sending unit. What are their purposes? Until I understand their functions, ignore this post, and it might be idiotic at this point.
I am bumping this back up because I tried to tackle this today. I even took the hood off! My problem is I don't think I have a deep socket large enough for it. I tried a 19mm and 3/4 with no luck. It fits around the sensor portion, but not the base where the 6 points are. Anyone know what size it could be so I can get the right deep socket size?
What is weird is that the new sensor I bought (from Toyota), seems to fit a 19mm deep socket just fine? Did they give me the wrong sensor?
Make sure that you are pulling the correct sensor. I put an '88 in my 94 (both were 3vze) and the sensor block was different from '88 to '94. The '88 does not have the rubber hose connected to the block of sensors like the 94 did. Also the location of the temp and other sensors were shifted around.
Grey connector? Between the TVV and the heater hose? That's the one, if so. Should be a 19mm. But, if you can't the socket down to the hex head, try using a plumber's basin wrench. Pretty cheap tool and can be used elsewhere in otherwise hard to reach applications. (I've done this.)
Um......it may be, and I may have been incorrect on the size. I admit, I don't have to get back there very often and go by memory a lot of times. Maybe 21 or 22mm?
the1998sr5
15
Jul 14, 2020 08:35 PM
taller1
Nov 13, 2018 02:34 PM
