Coolant leak back of intake?
Old Apr 25, 2024 | 06:37 PM
Renegade15's Avatar
I just pulled into the driveway and turned the truck off to hear a sudden hissing that was a very clear spraying coolant leak from somewhere in the middle of the back of the motor. I couldn’t get a clear look at it spraying as it was hot, but anything in particular, hose or fitting, I should focus on that may have cracked? Thanks!
Forgot to mention this is a 3.0 in a ‘95
Old Apr 26, 2024 | 02:08 PM
myprecious's Avatar
coolant bypass tube
something related to coolant bypass tube
Old Apr 26, 2024 | 03:20 PM
osv's Avatar
osv
i had a 22re with a crack in the water jacket, up and behind where the fuel filter is mounted, it was difficult to troubleshoot.
Old Apr 26, 2024 | 04:30 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Best to mention the year, type of engine, etc in your post
Old Apr 30, 2024 | 11:46 PM
scope103's Avatar
Bolted to the back of the head is this gadget:
The large tube is part of the heater system. Here's the manual section that describes it: https://web.archive.org/web/20141114...06operatio.pdf
There's a gasket below the gadget where it bolts to the head, and all of the sensors could leak, but I'm guessing you just split the heater hose.
So all you need to do is get it up to temperature and look for the leak, eh? No, you'll scald yourself for sure. Take the easy way out and pick up a cheap coolant pressure tester like this:
Amazon Amazon
Then you can pressurize the system cold and finding the leak will be easy.
84darknight
Aug 20, 2009 12:06 PM
Motomeister
Apr 4, 2009 02:12 PM
4RunnerFreedom
Jul 27, 2008 07:33 AM
Justinvd
Apr 3, 2008 04:55 PM
needayota
Jun 14, 2004 02:27 PM
