Coolant flush
Old Jun 17, 2005 | 08:55 PM
rimpainter.com's Avatar
Originally Posted by Ironmike4x4
Is the "red coolant" the same as GM's dexcool?
Yes, it is. And the best place to get it is Walmart. It was just over $9 for a jug; $1+ less than Autozone.
I also recommend the Redline Water Wetter treatment. I went for a 70% distilled/30% coolant mix for added performance.
Old Jun 17, 2005 | 08:57 PM
Ironmike4x4's Avatar
Then I most definitely will stick to my green coolant/water mix.
Old Jun 19, 2005 | 07:40 PM
Robinhood150's Avatar
Yeah, where do you get DI water, Tom? Last time I tried to take the garden hose into the cleanroom the operators looked at me funny.
Old Jun 20, 2005 | 08:11 AM
keisur's Avatar
Grocery Stores carry it in the water section, there's drinking water, spring water and distilled water.
Old Nov 10, 2005 | 11:47 AM
  #25
shazaam's Avatar
ok so I've never done this before.
1) locate drain plug at bottom of radiator, and drain coolant.
2)refill with water, and run engine, and heater until clear water comes out of the drain hole.
3) drain water
4) refill with 50/50 toyota red/distilled water
5) burp system, by squeezing top radiator hose?
does that cover it? Or did I miss something?
TIA
Old Nov 10, 2005 | 01:11 PM
  #26
vegaskurt's Avatar
I was told that if you flush all the red out, you can run anytype of green antifreeze. Is that true or bunk?
Old Nov 10, 2005 | 01:19 PM
  #27
EWAYota's Avatar
i've heard that with the older toyotas green is fine, red is recommended for newer.
Old Dec 9, 2005 | 10:56 PM
  #28
mach4's Avatar
You might want to get some coolant flush and mix it in with your first water fill and engine turn on.
Others might have opinions on the flush chemicals but I decided to do it since I had some pretty ugly/nasty stuff in the system from the previous owner.
Old Dec 10, 2005 | 01:36 AM
  #29
YotaJunky's Avatar
Originally Posted by Robinhood150
RWD, I paid $15+tax on the red stuff.
Steve
I've heard from a Toyota tech that the red and green Toyota coolants should not be mixed otherwise you may produce gel. If you started with green, hopefully you got it all out before you added the red.
Troy
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
Davebarbier
Nov 3, 2015 03:28 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
