converting rear heater to front
Just curious if anyone has ever reversed the rear heater so it blew up front. Wouldn't be too hard, just un-bolt and flip it so the vents point forward. I just wanted to see if anyone had pictures of this done.
You can`t just unbolt it and turn it around, you would have to cut a new hole in the floor for the coolant lines, then modify the coolant lines to hook them up. And by turning the heater around it won`t fit in the console and it still won`t blow any air to the front. If the heater in the dash isn`t working, just fix it, its not that hard.
You can`t just unbolt it and turn it around, you would habe to cut a new hole in the floor for the coolant lines, then modify the coolant lines to hook them up. And by turning the heater around it won`t fit in the console and it still won`t blow any air to the front. If the heater in the dash isn`t working, just fix it, its not that hard.
Winter will be done soon anyways haha.
You can buy 12 volt electric heaters that plug into the cigarette lighter, that would be the easiest to use. The mojave heater has to be hooked into the heater lines to work.
Why not just get some dryer ducting or similar, and duct the rear heater to the front?
Ya rear heater. PITA! Be prepared to run new hoses if you do anything with them. You will be cutting them off. I just decided to delete mine when doing my motor swap, but i would probably want to run it up front if i was in -35 temps too!
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
