Consuming Coolant
Old Dec 6, 2009 | 01:30 PM
cgeorge's Avatar
yeah.. they are!!
I noticed that when I removed the thermostat that it didn't have a gasket but an o-ring thing... is this normal? The FSM shows what I would call as gasket and I see parts sites that sell an o-ring and a gasket.. Mine wasn't leaking , BTW.
Old Dec 6, 2009 | 01:53 PM
sb5walker's Avatar
On my veezy (I know, different engine, doesn't necessarily apply to the 4-banger) it's just the o-ring - no housing gasket. In fact, using a gasket would hold the outlet out further and it wouldn't pinch the o-ring as tight, possibly causing a leak.
Being an earlier, japanese-made truck, the outlet is aluminum and fits so well that when I take the stat out and reattach the outlet (with no gasket or o-ring) to flush the system, it doesn't even leak. Gotta love that japanese quality. I agree, though, that $500 for a dealer rad from 1sttoyotaparts is a LITTLE bit steep, haha.
Old Dec 6, 2009 | 03:10 PM
pruney81's Avatar
on a 22re it's just an o-ring that goes around the thermostat
Old Dec 6, 2009 | 07:00 PM
flyingbrass's Avatar
Yep. Found that out after trying in vain to locate a gasket for the water outlet housing. A thin smear of RTV on the surface of the outlet stopped my small leak.
Old Dec 9, 2009 | 03:34 PM
  #25
cgeorge's Avatar
I just replaced my radiator, thermostat and upper/lower/lower hoses. I think I need to redo the thermostat because it was a little wet looking between the water neck and the manifold. Other than that - and burping the system several times - I think I'm good to go.
I now have to figure out what to do with my carb. It is running pretty rich. This was extremely evident while I was working in my garage over the last day doing the flushes. Even with the garage door open and the wind blowing it almost suffocated me.
I think the PO carb rebuild was poorly done. I can't believe that I'll need to buy a kit as well as a float and it will cost over $120....
Old Mar 8, 2010 | 04:21 AM
  #26
Riozpr's Avatar
This is all really good advise i have a 22re that was rebuilt not overheating or anything but its drinking the antifreeze also.. and i have no heat...
does the 22re system have to be bled?
ladybugRC
458
Aug 21, 2020 10:41 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
wberry85
May 17, 2016 05:45 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
