cone filters vs airboxes (comparison with support)
OK guys, I know that many of you have already seen threads discussing these filters before, but now as a "school project" for community service, I will go over how to make your vehicle more economical in the way of using less gasoline.
First off, the key to conserving gas is not with the air filter but how you drive:
1: Don't drive aggressively (punching the gas, accelerating fast, etc)
2: Shift early (only applies to manual transmission...
3: Do regular maintenance on your vehicle and for those that tinker with their engines, make sure that it is timed properly.
Now, as for open element air filters, there has been debate over whether these types of filters really do provide a noticeable increase in horsepower. This is a fallacy first off. Open element air filters really only provide "more access" or unleashes more of your engines available horse power. As for the Toyotas on this forum (especially the 22re) the horsepower is not all that impressive of a number compared with the mileage on the odometer. However, after adding an open element filter, I have noticed a slight (note the slight) increase in starting power and acceleration.
Now, regarding the gas mileage using an open element filter, I have found that an average tank using the stock air box equipped with my 94' pickup's 22re got me 197 miles. Now, the two tanks that I have filled up after installing the open element filter have averaged at getting me 213 miles to the tank.
It is important however to address the variables included with this installment. My reason for installing the open element filter was because of a car crash that obliterated the existing airbox beyond repair. Thus, it was cheaper to install and after market air filter than buy a new or used air box. The discrepancy in gas mileage, though points to the fact that open element filters allow for better gas mileage, it could also indicate a change in my style of driving (for the better) after the car crash. Looking retrospectively, I would say that although the crash has been a personally costly experience, if it means that I am a safer and more economical driver, it was an overall beneficial experience (especially considering the knowledge I have gained).
Now for the question of debate: Is it worth the money to buy an open element filter?
This is really a personal question to you. Do you consider your carbon footprint on the world through using your car? If you truly did care, you would have gone out and gotten a Prius instead. However, if you do worry about your gas mileage and how much money you would save by purchasing an open element filter, it would take 20-30 full fillups before you equaled your spending on a similar setup (mine was $47) depending on the cost of gasoline in your state. If you are concerned about just the power gain from an open element filter, then by all means get one, as it does increase the initial acceleration and has a noticeable increase in horsepower.
My setup:
Thank you for reading (hopefully you did)
)3: Do regular maintenance on your vehicle and for those that tinker with their engines, make sure that it is timed properly.
My setup:
I didn't notice a mpg gain, but I did notice throttle response changed and the engine pulled better at mid-high rpm and maybe even came on its power band earlier. My engine seemed to start to make more power around 2700rpm with the airbox. With the cone filter, it starts to pull at 2400rpm.
Good writeup, thanks.
open air filter
sorry dude but i disagree, unless you arnet running a hood than all you are really doing is pulling in hot dead air from the engine compartment, plus you are collecting any other krap that goes in there, if i was you id get an are box from a salvage yard, and add a k&n to it mabe take out the baffle if you do so desire.
To get proper mileage figures you need to do a little more work than just saying how many miles to a tank. You need to run no less than 10 tanks worth through and get a figure by dividing how many miles you drove from your last fill-up by how many gallons you just put in. For example, on my last fill-up, my truck went 228 miles and it took 12.3 gallons to fill. 228/12.3=18.5 mpg. This obviously isn't going to work because you don't have a stock airbox to compare it to.
I would like to see more "support" before you can definitively say that an open air element would net more MPG and how much exactly.
My setup:
My setup:
I think you need to be careful though with shifting early. I believe the 22r/re is a high revving motor. So if you shift "early" you are making the CLUTCH pull the weight of your vehicle versus the engine pulling the weight of the vehicle.
I think coming out of first gear especially you need to bring the RPM's up some lest you put extra wear and tear on your clutch.
then again if you don't mind replacing clutches, moot point?
Check out Ace's dyno testing here: https://www.yotatech.com/51031296-post250.html
A quote from link above:
So I put the stock intake back on in disbelief that it made more power, made another run and sure enough gained 5 – 10hp over the next 3 pulls over the pulls just a few minutes before. So strange as it may sound the stock airbox IS better then those short-ram/Cold-air intakes! Surprising to me.
I was really skeptical about cone filters, but one came with the truck, and I got bored one day, so I bolted the cone on and it did make a difference. I didn't have any bias because I didn't buy the filter myself.
I just run five or six tissues soaked in Canola Oil duck taped to my intake plenum. I'm getting 300 rwhp!
Not really. I've run them both. Seen 2 motors get hydrolocked because of failed cone filters. I'll stick to my deckplated airbox, thank you very much.
Besides...they remind me of small cars with large stickers and park benches bolted to their trunks.
I would think cone filters would be less prone to hydrolocking as the intake is inside the engine bay vs. behind the headlight. Unless you immerse up the engine bay, your not likely to hydrolock w/ a cone filter, but splashing the headlights is all too common an event.
The filter location on a 3.4 would make me nervous with a cone. Of course, I put in my deckplate anytime it rains heavier than a drizzle (which out here isn't very often to say the least).
