Con rod bearing identification help please
Old Mar 6, 2013 | 09:40 AM
redzed's Avatar
Hi everyone,
I just removed the oil pan on my 1994 22RE pickup because it was leaking and I would like to replace my con rod bearings at the same time, without machining the crank.
I inspected the crank and it seems like it's in very good shape. I'm doing this to be preventative more than anything.
My problem is that I don't know what size the bearings i removed are. They don't say "standard" or .010 over etc.
The only markings on the bearings are:
76
then below that is: 4G52L
Here is the pic:Name:  photobearing.jpg
I would like to put the exact same size bearings back into the truck.
Could anyone shed some light on what size these bearings are? Are they standard?
Your help is much appreciated.
Thanks
Old Mar 6, 2013 | 12:37 PM
redzed's Avatar
Can anyone at least tell me what brand these bearings are?
Looks like (lh) right beside the numbers..
Old Mar 6, 2013 | 02:40 PM
wyoming9's Avatar
Red face
Have you miked the rod journals to see what size they are?? pretty much just taking a guess otherwise.
Have you owned this truck since new??
At the least did all the bearings have the same numbers??
Hard to tell if this is the first time this engine might have been apart.
Your in this far and your also not going to do the main bearings as well??
Old Mar 7, 2013 | 07:43 AM
redzed's Avatar
I haven't measured the rod journals. I'm the fourth owner of the truck and yes, the bearings did have the same numbers.
I found the markings on the bearings odd and wanted to check with this community to see if anybody had seen similar bearings/markings. It would be nice if i knew what brand they were so I could try to dig up some info using those numbers.
Old Mar 12, 2013 | 08:18 AM
Swiftshifter's Avatar
Virtually the same dilemma for me right now, so I'm curious as the responses. I used Google for the rod bearing part numbers and amazingly came up with nothin'. That was a first. I was 13ft. from my engine room and my micrometers last night and didn't grab 'em and do a quick check (never thought I'd have trouble replacing "in-hand" bearings/part numbers).
Old Mar 12, 2013 | 08:25 AM
Grego92's Avatar
"IH" is the Taiho logo
Does it look like this?
http://www.taihonet.co.jp/e/company_o.html
They are OEM supplier to Toyota for bearings...when I replaced mine that's what they were and that's what I replaced them with.
Marley2984
Dec 6, 2015 05:19 AM
Lons81
Nov 23, 2015 09:25 AM
Pitbullblues
Sep 19, 2015 08:19 PM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
