Compression test results......
Old May 28, 2008 | 11:38 AM
Marc's Avatar
# 4 is fine. Well within spec.
Old May 28, 2008 | 11:42 AM
Team420's Avatar
I though spec was..... no more than 2% difference between cyl?
Old May 28, 2008 | 11:56 AM
toytech76's Avatar
Spec is within 10-15% of each other
Old May 28, 2008 | 12:02 PM
Team420's Avatar
Oh...well I'm not worried about it then...thought it was 2%, guess now I just need to find my vacuum leak, coolant leak, and replace the knock sensor...or rewire it to the ecu...thanks guys....yotatech rocks again!!
Old May 29, 2008 | 06:31 AM
  #25
Red_Chili's Avatar
If you are losing coolant and have white smoke on startup, scope your cylinders to find out if it is indeed what it seems to be. Clean piston top is bad news. If so, yeah, you are headed for a teardown and I wouldn't drive it until you confirm all is good.
eggens
Oct 27, 2015 03:14 PM
_Nicco_
Sep 21, 2015 03:06 PM
Yont283
Sep 20, 2015 10:56 PM
Yont283
Sep 12, 2015 10:03 AM
Boomer8404
Sep 10, 2015 09:01 AM
