Cold Start injector intermittent, HELP!
Old Feb 21, 2018 | 08:06 AM
  #161
YotaRick27's Avatar
Question
Originally Posted by Co_94_PU
You can measure efi relay voltage and voltage drop by back probing it (tpin the wire connector), voltage on each side measured to battery ground and voltage drop from the input to the output.
I'm a little confused on this part. So put t-pins in each relay female plug and test the voltage from the pin to the battery ground?
Old Feb 21, 2018 | 08:32 AM
  #162
Co_94_PU's Avatar
skip the drop test. Just re check the voltage at the ECU, you've done this one before, if it's still low compared to battery voltage we can revisit the where, how, and why.
Old Feb 21, 2018 | 09:36 AM
  #163
YotaRick27's Avatar
Cool
Ok i'll post the updated info as soon as I get off work.
Old Feb 21, 2018 | 04:33 PM
  #164
YotaRick27's Avatar
What should my battery voltage be sitting at not running? Started with 12.48v after cranking but no start is now at 11.88v very very slowly going up
Old Feb 21, 2018 | 04:50 PM
  #165
Co_94_PU's Avatar
12.6 is normal. What does it read while cranking?
Old Feb 21, 2018 | 04:55 PM
  #166
YotaRick27's Avatar
I took a video I will post. 12.27v sitting then when I crank it drops to 9.98-10.00v
Old Feb 21, 2018 | 05:03 PM
  #167
Co_94_PU's Avatar
better than I expected but probably low enough to stop it from starting. It's going to want a jump probably.. I expected it would be low from the readings the other day, low twelve followed by the high 14
Old Feb 21, 2018 | 05:06 PM
  #168
YotaRick27's Avatar
Bad battery?
Old Feb 21, 2018 | 05:12 PM
  #169
Co_94_PU's Avatar
Bad battery?
only if it is still under warranty
It's been really cold, a drained battery is more likely to freeze and get damaged than a fully charged one, and hasn't been getting lots of charge time and has gotten lots of drain from the testing.
Old Feb 21, 2018 | 05:15 PM
  #170
YotaRick27's Avatar
I’m going to go steal a friends tonight because I don’t have a charger other than it running. I did check fuel pressure for you but did not test ecu because of low voltage at the battery
Old Feb 21, 2018 | 05:21 PM
  #171
Co_94_PU's Avatar
A 20ft' set of jumper cables comes in really handy, can jump start most rigs by just getting near the rear bumper.
If you can get cables to it five or ten minutes will get you going.
Old Feb 21, 2018 | 05:26 PM
  #172
YotaRick27's Avatar
I know lol. I have jumper cables but if the battery is going out I need a new one anyway I’ll jump it and see if that makes a difference before grabbing his battery. But if it’s running and charging at 14v why would it die out. Doesn’t this eliminate the battery being an issue
Old Feb 22, 2018 | 07:12 AM
  #173
YotaRick27's Avatar
Well schucks after typing 2 full paragraphs it times out and lost it. so again: I prommied you voltage checks and fuel pressure. Voltage checks will have to wait due to my having low voltage last night and waiting for my wife to come home so I can jump my truck. Fuel pressure was 39psi at cranking and 35 when not cranking. I could not get it to fire up last night even after being jumped. even the AFM delete then plug in trick did not work. I did however get a call yesterday from the doc saying I have strept throat so thats fun. I took friday off to do nothing but work on the truck so either tonight or tomorrowi will have the updated ECU voltage checks for you.
I did want to re-tackle the issue of a possible flooding. it makes sense that if the truck starts and runs great cold then once warm is getting to much fuel then dies. Possibility 1: cold start injector is leaking(even though its unplugged) Possibility 2: coolent sensor next to the cold start injector time switch is giving motor mixed signals.
What to check? maybe pull a plug and see if its wet? Pull intake and see if intake galleys are wet (they were last time I pulled the intake). Ideas? suggestions?
Again I very much so appreciate all the Help and sorry for not grabbing the voltage checks.
Old Feb 22, 2018 | 07:44 AM
  #174
Co_94_PU's Avatar
..I could not get it to fire up last night even after being jumped. even the AFM delete then plug in trick did not work...
... Pull intake and see if intake galleys are wet (they were last time I pulled the intake). Ideas? suggestions?
Why is your cold start injector unplugged? You did not think this is part of why it would not start in the cold?
Need more details on the wet intake. "You have to put us in front of the truck."
To clear a flood condition, unplug cold start injector, pull efi fuse, crank engine with throttle pedal to the floor. (Crank for ten to fifteen seconds, let it cool off for sixty to avoid heating of starter and fusible links ect, then repeat.) Plug those items back in and try to start it normally. If it doesn't start verify spark.
Old Feb 22, 2018 | 07:50 AM
  #175
YotaRick27's Avatar
Exclamation
Exactly. Besides, the CSI will not cause NO-start, unless it is leaking.
I do not think Yotarick's TS is stock. Here's what I have on my 1986 that runs well (with very occasionally rough idle after warm start that goes away as soon a I pull out of my parking spot):
Ok so I can clear this up and eliminate this as a possibility, What is the color wire for the coolant sensor the inlet in between the 2-3 fuel injectors? What is the color wire going to the top radiator hose inlet tube coolant sensor? Both at the ECU and the sensor connection.
From what I am gathering at the ECU one is TSW and the other is THW correct?
Old Feb 22, 2018 | 07:54 AM
  #176
YotaRick27's Avatar
I only unplugged the CSI after started to test if it was a issue of cold start injector time switch going bad. When would i do this test? In a no start position or after running normal?
Old Feb 22, 2018 | 08:01 AM
  #177
YotaRick27's Avatar
So After work today and tomorrow my goal is to identify TSW and THW and verify they are operational as well as to do a flooding test after I get updated ECU voltage for # 1,2,3,6 and 11.
Old Feb 22, 2018 | 08:11 AM
  #178
Co_94_PU's Avatar
You test if the CSI is leaking by pulling it away from the intake (leave it plugged in, leave it plumbed to fuel), like in the video, power up the fuel pump and look at the injector. There is a spec for so many drop over a span of time, neither number I remember, as long as it's not a trickle or worse I wouldn't worry about it.
The picture is of the wet your are concerned about? Looks like oil from here, from the positive crank pressure valve (PCV), fuel would have evaporated while you were doing all that wiring.
Old Feb 22, 2018 | 08:19 AM
  #179
YotaRick27's Avatar
ok I will pull the CSI with everything plugged in and check for a leak. Would hot or cold make a difference? If no leak then next step would be coolant temp sensor to ECU next to time switch?
Old Feb 22, 2018 | 08:24 AM
  #180
Co_94_PU's Avatar
we have been over the wiring a few times already.
Put your meter to the beeping continuity mode, unplug wire from the sensor, Clip probe to the wire in the engine bay, take the other probe to the ECU, when you get a beep take a photo.. Show us where it goes and what color it is. There is absolutely no better way to be sure what wire goes to what.
TSW, is/was in the loom between the intake runners. Think it's typically brown or green.
THW, is/was in the front loom. From memory its with the CSIsw and tps.
Get us a photo of the sensor between the cylinders. I think at some point you said you have an aftermarket temp guage there?
