Cold idle lope 88 3zve 4wd.
Only when tempature is below 40*F the engine fast idles 12-1300 rpms. It will only lope when the brake and clutch are pressed. If only brake is pressed, it will not lope nor if only the clutch is pressed. It will not lope in warm tempatures, at all. Yet in the winter if the engine temperature is close to 180*F it will stop loping.
mtb83201
Nov 16, 2013 06:42 PM
