code 21 how to fix?????
I just pulled the code for my check light and i have code 21 saying that i have a heater or main oxygen sensor. i dont fully under stand what this means and how to fix it any help?
I pulled the same code when I did mine a few weeks back. As I understand it the code 21 is one of the three things you said above ecu, hot o2, or the hot o2 circuit. Have you done any messing around with any wires lately?
if so i do not think that has anything to do with your problem
are you having any drive ability issues?
check your wiring, map the wires from the ecu to the o2 sensors, check the ground to the ecu, replace the o2 sensors. it must be one of those three things. this coed only happens on the California models.
mines been running like shat for a while and pulled the same code. I plan on mapping the wires form the ecu to the o2's this weekend when i get some time.
thats right. Should have 2 or 4 wires coming out of it, and bolted into the exhaust pipe.
Checkout toyotapartsales.com for the best prices on OEM parts.
You can get an aftermarket one, but BUYER BEWARE! Low quality taiwan junk will only cause you problems.
wow thats pricy i think ill deal with the light lol now cuz i have the cat hollowed (yall came hate me if u want) adn the flowmaster on it could this be why it keeps going off? it seems to only come on when i cruise in 5th and once its on its on for a while. Then all the suddon bam its off till 5th gear
thats fine, deal with the check engine light. Meanwhile, its costing you 2-3MPG. At $3.25/gallon, in about a month it will cost you more money to "ignore the light" than to fix the problem.
But you do whatever you need to.
