Clutch wont engage
Old Mar 27, 2012 | 12:51 PM
matanzasace's Avatar
Clutch wont engage
Hey all, new to this forum. Got a 93 3.0L P/U 4x4, recently truck didnt want to go into gear, mainly first and second. Well I replaced the master cylinder and the slave then bled the line and clutch still wont fully engage. Im gonna try rebleeding, but are there any thoughts on this? The pedal assembly is fine and not cracked and the clutch itself is only 6 months old. Also I noticed there is a little play on the pedal before it gets stiff to the floor. Not sure if that has something to do with the components and the line or the pedal. Need help because the truck not driveable as of now.
Old Mar 27, 2012 | 01:26 PM
JonnyBoy's Avatar
There is an adjustment on the pedal, not sure if you've tried that yet. It is possible to have a bad master or slave right out of the box, too. Seems like the only things I can think of that would cause these symptoms, good luck.
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
primordialbeast117
Dec 19, 2015 12:23 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
