clutch slave bleeding weirdness... thoughts?
Old 01-10-2012, 07:41 AM
jonnydclark's Avatar
Hi,
I've just replaced the clutch, rear main seal and flywheel on a 91 3.0 4runner. The clutch slave was working before I started as I verified the slave was pushing the lever.
During the job, I started the engine with the trans out of the truck and let it run to verify I had solved the oil leaks. To do this I pushed the clutch down to engage the starter.
Now, I have no clutch fluid movement. I have pulled a vacuum on the line itself as high up as the firewall to prove that i didn't kink the line somewhere. The vacuum will hold at 25 inches for 30 minutes without dropping, there is fluid in the master cylinder and the cap is off the master cylinder. I have no clue what I did but feel that I must have flipped a valve or something funny when I pushed the clutch in while the slave was in the air.
Anybody had trouble and what am I going to run into if I try to pull the clutch master cylinder off and try to blow it out or clean it out?
Thanks for your ideas.
Old 01-10-2012, 08:19 AM
alltracman78's Avatar
You may have overextended the master cylinder.
Have you tried removing the line from the MC and pumping it?
Seeing if any fluid comes out [obviously with a full res].
If none does, you need a new master.
Old 01-10-2012, 08:27 AM
92 TOY's Avatar
I imagine you spewed the guts of you slaver cylinder out across the garage floor somewhere. happened to us while the motor was out and my son pressed the clutch in while it was detached. new AISIN was not very expensive and is another job that won't have to be done for a while.
but, the tell-tale sign was the puddle of fluid under it. if you didn't have a puddle, not sure.
Old 01-11-2012, 12:04 PM
abecedarian's Avatar
It's possible that without the slave pushing fluid back to the master, the piston in the master is stuck at the far end of the bore. Maybe try blowing some pressure up the line to the master then bench bleeding it.
You don't have the "Clutch Start Cancel" switch?
Old 01-11-2012, 12:41 PM
wyoming9's Avatar
Red face
You pushed the clutch pedal in when the transmission was out.
Where was the slave cylinder??
Had you removed the line and left it attached or was it hanging there.
When you pushed the pedal it had to push the piston and fluid out of the slave cylinder if the boot kept it from flying across the room .
fill the master cylinder with fluid check the piston and rod are in the slave cylinder in the correct place.
bleed as needed
it is no different then having any type of failure in this system
Old 01-11-2012, 01:08 PM
Thanks guys.
No there was no fluid leaking from the slave and yes the piston was still in place. That was the weird part, even with the slave disconnected and a pump holding -25 inches of vacuum and a full master cylinder I couldn't get more than a few drops of fluid to come out.
So I disconnected the MC rod from the pedal lever and pulled it back a little and wiggled it around. When I did so I heard a sucking gurgling sound and then all the fluid went out. After installing the slave back on it and bleeding it works perfect.
So it took me 2.5 hrs to pull the tranny, about the same on getting the bearing out of the crank and about the same to get that slave thing figured out. The joys of learning.
To get the bearing out I finally ended up using an air chissel to break out all but the inner race then I could get the rented puller and slide hammer to work on the outer race.
Old 01-11-2012, 01:09 PM
. Totally didnt think of it. My dd is an auto and I haven't driven a stick for a few years. I think I'll remember it next time. ;-)
Old 01-11-2012, 01:13 PM
So it's fixed now?
(for what it's worth, we all do bone-headed things- overlook the obvious.)
Old 01-11-2012, 02:36 PM
Yes drives great now. I probably didn't need the new slave but for $12 I kept it.
09-04-2015 09:27 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
HookahRoo
07-20-2015 07:06 PM
Edionne13
07-09-2015 01:59 PM
Quick Reply: clutch slave bleeding weirdness... thoughts?
