Clutch / shifting problems
Old Dec 24, 2011 | 08:54 AM
west_89_'s Avatar
i have the same issue i didnt know GL-5 can cause an issue i will be checking to see if thats what i put in.
Old Dec 24, 2011 | 09:12 AM
west_89_'s Avatar
also my seat and bushing seem to be shot as there is lots of play in all gear and a significant amount in 5th and reverse. i will replace them aswell as the gear oil if it is GL-5. and let you know.
thanks yotatech! saved my butt once again!
Old Dec 24, 2011 | 06:23 PM
Turd Furgeson's Avatar
Did you double check the clutch fork while it was out? My friend had a similar problem and replaced everything. Then we noticed a tiny crack in the clutch fork. It was letting the end of the fork flex enough that it wasn't moving the fork that much.
Old Jan 1, 2012 | 08:58 AM
west_89_'s Avatar
no i replace the fluid with the right transmission fluid now it works like a hot damn now i just need to replace that bushing where my stick shift goes in to the tranny
Old Apr 18, 2012 | 03:42 PM
  #25
Hellvision251's Avatar
Originally Posted by jpoe
Thanks for all of the input. With any luck, it will be the bracket and I can fix it with the welder, and prove to my wife that, I did in fact, need to buy that welder!
amen to that brother!!!!!!
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
the1998sr5
Jul 16, 2015 06:20 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
