clutch pedal bracket broken AGAIN!! is this a common thing??
Old Feb 5, 2008 | 04:49 PM
Swank's Avatar
I said screw it and went and got a new one at the dealer. Its a shame we have to pay money to replace a defectively designed part.
Came out in about 1 hour when back in the truck in less than 1 hour.
Old Feb 28, 2008 | 07:13 PM
n8buddy's Avatar
i just found myself with the same problem, but i have a few questions.
1) I tried taking the bracket out myself, but i could not maneuver it out, even after a took the brake pedal off. whats the trick and what do you have to do to the steering shaft to slide it out?
2) i also found that the bracket also has 2 bolt that bolt up from the top of both the brake and clutch pedal hinges into the body. The one above my clutch broke the nut and a chunk of metal right out. did anybody have the same problem and what did you do about it?
i took it to my 'mechanic' after i couldn't get it out myself, and he charged me $120 just the stitch weld it back together, no gussets or anything, he didn't even take it out. to take it out he said would be a 10 hour job because he would have to take the entire dash apart. wtf? time to find a new mechanic i guess if you guys say it takes you less than 2 hours.
Old Mar 2, 2008 | 07:55 PM
n8buddy's Avatar
anybody? i had a look at what the mechanic did and its a hack job, i can feel if flexing whenever i push on the pedal. how do you get the bracket out!?!?
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
mtb_taco
Jul 15, 2015 08:36 AM
jon.r
Jul 11, 2015 03:34 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
