Clutch? Help???
Old Aug 3, 2007 | 03:21 PM
94_YotaKing's Avatar
Clutch? Help???
My 94 Pickup has gone again, this time something to do with the clutch. I was driving put it nuetral pressed clutch to put in gear and it went in gear but stalled and clutch pedal never returned to original position. clutch will not stay when pulled out then pressed again it just sits on floor. it feels real soft and loose checked everything under dash, springs levers, etc. looks normal. Please tell me what it could be and how to fix it thank you so much everyone.
Old Aug 3, 2007 | 03:30 PM
95_4MuddinSr5's Avatar
your screwed!
Old Aug 3, 2007 | 03:37 PM
runethechamp's Avatar
My guess is there is a leak in one of the following:
1. Master cylinder
2. Slave cylinder
3. The pipe between these, expecially the flex hose right by the firewall on the passenger side.
Old Aug 4, 2007 | 03:22 AM
TORTIS's Avatar
i agree with the above posts. did you let the fluid get low in the master cylinder?
Old Aug 4, 2007 | 10:30 AM
drew303's Avatar
yup, check the master clutch cylinder the lines connecting it to the slave cylinder (on side of transmission bellhousing)
probably find something wrong with em
Old Aug 4, 2007 | 10:40 AM
DeathCougar's Avatar
Originally Posted by 95_4MuddinSr5
your screwed!
well that was a helpful post...btw its You're, not your
I would say clutch master. Check for leaks, see if the slave or the master are leaking.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
