Cloud of Exhaust after start up
Old Oct 13, 2007 | 04:19 PM
fattirerider's Avatar
Originally Posted by CyMoN
is it cold where you are at?
No it is very moderate this time of year.
Old Oct 13, 2007 | 04:28 PM
nix4x4's Avatar
Just to throw something different out there, I had a really bad smoking problem a while back. Turned out that the valve from the power steering pump to the intake that ups the rpms at full wheel lock went bad, causing power steering fluid to get sucked through the intake. This caused smoking but didnt smell funny. Check you PS pump. just thought I'd chime in.
Old Oct 13, 2007 | 04:36 PM
n4ynu1010's Avatar
all of my cars or trucks I have had did an do this on cooler mornings and it was just condensation,
now I did have a mazda that had a bad piston ring or valve seal
and in the winter mornings after sitting all night oil leaked into the cylinder and the truck would burn oil for 10 minuets until it warmed up and when I say it burned oil you could not see the truck running in the front yard if there was no wind looked like the house was on fire.
At least you would keep mosquitos down daily
Old Oct 13, 2007 | 08:07 PM
CyMoN's Avatar
Originally Posted by n4ynu1010
At least you would keep mosquitoes down daily
lol no mosquitoes when it is 10 or -10 out and the neighbors must have loved me
Old Oct 13, 2007 | 08:19 PM
  #25
thook's Avatar
Originally Posted by fattirerider
Thanks for the reply! Yes this sounds correct about the condensation build up. I do notice more when its gotten colder thhis time of year and does stop after its warmed up. I'll check the oil and radiator today aswell.
This is the answer I was looking for, the others kept me tossing and turning last night.
Nice, eh? I thought that might cheer you up.
So yeah, don't worry about it. If it were fuel, it would be black smoke...and oil would be bluish. Plus, both smell like what they are when they burn.....carbon. And as stated, a leaky headgasket would give off a coolant smell.
Just for illustration, once you've started the vehicle after it's been sitting overnight or for an extended period, look at the exhaust tailpipe. It will drip water while it's burning off the condensation. Oil and fuel burning will not have such a byproduct. The headgasket/coolant thing I'm not sure on. I've never actually been in the presence of a vehicle with a leaky hg.
Old Oct 13, 2007 | 08:41 PM
  #26
toyotatom93's Avatar
My truck also smokes a bit on startup, but I have also noticed it smoking after it has been warmed up for a while. The other day I was adjusting my brakes by stopping in reverse and I really noticed it then, white smoke that smells like what I thought was burned oil.
There is no indication that anything is wrong with my HG, oil is proper color and coolant levels are good. Compression was about 170 in all cylinders in May when I bought the truck and it smoked then. I came to the conclusion that my valve guides are leaking oil to explain the smoke on startup. But if shes still smoking after shes warmed up does that mean my rings are going?
At any rate the truck runs great and I would say I dont have any power loss or anything besides the lack of balls. Just concerned to the well being of my baby.
Old Oct 13, 2007 | 08:56 PM
  #27
thook's Avatar
Look again. Are you sure it doesn't have a blue hue to it? Have you looked at your plugs lately? Or even checked your compression lately?
Old Oct 13, 2007 | 09:11 PM
  #28
Yes a little water is pushed out ones she warms up.
Really thanks for the help! Made my weekend
Old Oct 13, 2007 | 09:14 PM
  #29
thook's Avatar
I'm sure it did. Relief is always a nice thing.
And you're welcome.
Old Oct 13, 2007 | 09:42 PM
  #30
Havent really noticed if it has a blue hue to it, I will pay more attention next time, but I think it did. I pulled the plugs and they all seemed ok, but the threads are all black. And on the first one I pulled the tip had a gray ash I could scrape away with my thumb. Wire brushed them all. I dont have the means to check compression my self.
Old Oct 13, 2007 | 10:33 PM
  #31
thook's Avatar
Yeah, take another good look. I does sound like your burning oil, but not much. So, nothing to worry over immediately. Just keep an eye on the plugs, oil level, and compression.
Old Oct 13, 2007 | 10:49 PM
  #32
Thanks. I figured it wasent that big of a deal, but since I never really had an interest in motors till now I dont really know all that much about these kinds of things.
Am I correct with the statement that if it smokes bafore its warmed up it is the guides, and smokes after its been running for a while it is the rings? or is it not that simple. I do use roughly a quart of oil a month and it doesent leak a drop on the ground.
Old Oct 14, 2007 | 06:17 PM
  #33
corvey's Avatar
Originally Posted by toyotatom93
if it smokes before its warmed up it is the guides, and smokes after its been running for a while it is the rings
That's what I would have said...
Old Oct 14, 2007 | 06:26 PM
  #34
n4ynu1010's Avatar
Need a 4 wheeling Gecko hehe
Old Oct 14, 2007 | 06:29 PM
  #35
corvey's Avatar
LOL! I had already thought about that!!! Maybe when I get some free time I can use my geek skillz to animate one up
Old Oct 14, 2007 | 06:36 PM
  #36
n4ynu1010's Avatar
HeHeHe
Jun 1, 2021 01:51 PM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
