Clogged Catalytic Converter
Old Jul 22, 2013 | 07:22 AM
elaketiger's Avatar
My 3.0 gets poor gas mileage (9 mpg mostly on highway) and has poor power (even for a 3.0). It seems to run smooth, just low power. It's been recently rebuilt - completely.
I have set the timing, changed the knock sensor and cable, O2 sensor, plugs, wires, cleaned the throttle body, and checked for vacuum leaks.
No codes.
What is the likelihood the converter could be the problem?
Old Jul 22, 2013 | 08:52 AM
highonpottery's Avatar
is it glowing red after you drive it? that's a dead giveaway that it's clogged up
Old Jul 22, 2013 | 08:55 AM
elaketiger's Avatar
Never looked, but I'll check the next time I drive it. Thanks
Old Jul 22, 2013 | 09:51 AM
scope103's Avatar
Since the converter is downstream, the only way it could cause anything would be if it was REALLY clogged and raised the back pressure. Doesn't sound like the place I would start looking. (Glowing red could also be retarded timing, but in any event it is a 'bad thing.')
It is hard to imagine how your mileage would be so low unless you were running really, really rich. Smoke? You can check the mixture more-or-less directly by watching the O2 Sensor. http://personal.utulsa.edu/~nathan-b...01heatedox.pdf
kawazx636
Oct 6, 2021 03:03 PM
Cycles
Sep 29, 2015 06:37 AM
voiddweller
Sep 28, 2015 11:21 PM
Scotttekoch
Sep 28, 2015 10:30 PM
larrys93pickup
Sep 17, 2015 07:05 PM
