Clinometer?'s
Old Jul 24, 2007 | 04:27 AM
91 4Runner's Avatar
Clinometer?'s
I got this the other day at a local pick & pull, it's out of a Dodge Raider, but it'll do...
There are 4 wires for the guages. The Amp has red/blue & black and the Oil has red/blue & yellow/black. I'm going to install it in my 89 4Runner (non sr5).
Now here are my questions..... What wires do I connect them to in the wiring harness for the guage cluster? Or can I even use the guages?
Old Jul 24, 2007 | 06:32 AM
CyMoN's Avatar
you will need the sending units from the raider would be my guess
Old Jul 24, 2007 | 07:07 AM
4Crawler's Avatar
Looks like oil pressure and battery voltage plus the clinometer gauge. For battery voltage, that would be some wire that has switched 12V on it, like the cigarette lighter. Likely the o/p gauge will not work unless you can add a sender for it to your engine. The 3rd and 4th wires would likely be ground and the backlight wire. The clinometer itself does not require power or a sender.
http://www.4crawler.com/4x4/CheapTri...l#Installation
Old Jul 24, 2007 | 09:11 AM
thook's Avatar
That's spiffy. Hope it works for you.
Old Jul 25, 2007 | 02:32 AM
91 4Runner's Avatar
Thankls for the responses. And thanks Roger for the link. If the O/P guage wont work I'll find another aftermarket guage to put in there, or maybe a cumpass. That's if it can be disassembled that far...
diingodog
Jan 11, 2018 10:39 AM
jdwilson
Jan 30, 2010 10:31 AM
89silverpu
12
Aug 7, 2009 09:39 PM
mtbdavid
Aug 23, 2005 02:36 PM
Bob_98SR5
17
Apr 1, 2004 09:01 PM
